United States
I should mention these items I want to add or create a library are items I have downloaded from 3D warehouse sketchup site for designing my office items, would that effect this? And, sorry, I have a couple different folders with my 3D items. One is from years ago that I just kept adding to and now I have added the new version of SH3D, which I see there are new libraries in my C:programs\Sweet Home 3D. I only have the new version installed
United Kingdom
Hi, I'm new here so excuse me if this is an old problem, I did search but found no answer -:( is there a fix for high res screens for the furniture library editor my eye sight is not what it used to be and I need the big fonts. thanks and sorry if this is the wrong place to ask
You could try to use the same properties as the ones proposed for Sweet Home 3D. To run a Jar executable with these properties, you don't need a .ini file but rather directly cite these properties after java :
The problem with this solution is that the resolution scale won't influence the height of rows in the table of the editor, so text in the table might be cut for a high value.
As Java 9 is supposed to have fixed problems with HiDPI screens, it might be interesting to give it a try too. If it works correctly, then no need of any option, just double click on FurnitureLibraryEditor-1.21.jar file.
I recently installed SW3D for the first time and created a model of our house. Love it! Thank you VERY much!
Running SW3D 5.6, JRE 1.9, Windows 8.1
Now I'm importing SH3F files from various sources, like furniture stores that provide models. After downloading hundreds of these files I found I was unable to use the default Import feature to import more than one file. So I ZIPped the files, and while the UI refreshes and says new objects were were imported, that's never the case.
So I found the FLE here, downloaded v1.21, and while it does accept multiple files, it doesn't import the data to SW3D with the same detail as just opening a .SH3F file.
So as a user I'd like to know if I'm missing anything, and how I can import hundreds of files (with FLE?) without doing it one at a time.
As a developer, I'm happy to do some diagnostics and even (with very limited time) get into code to try to help with this.
For an example of files that import differently, see the M2Italia furniture site.
