Romania
Re: Furniture Library Editor Beta released
You miss few steps. The name of file is not the same with name of category. In same file you could have more category. After you load the furniture in furniture library editor, select all and then click on modify selected furniture (the 8 icon from left); in the new window edit the category name. You must see it in the category column (the 4 col.). Now you can save Your library under whatever name you want. When you import it in sh3d will see the category name not the name of the file. dorin
Hi, your question may be a bit confusing, at least to me. Toolbar Icon 8 from left in Furniture Library Editor is Modify selected furniture (in SH3D, nr 8 is Copy - and as far as I can tell it works according to convention?).
But obviously I am missing something. Maybe you could elaborate?
Romania
After this save your furniture library under what name you want. Dorin
Hello,
I made a bad manipulation and I do not know how to cancel ?
If this function does not exist, it is important to add it ;-)
Small notices:
To add a column of information with the "PRICE" of the imported 3D objects, would revolutionize the use of 3D Sweet home.
By exploiting the file CSV, it would be possible to make the evaluation of the prices at the same moment as the plans of our house.
On www.composant-dynamique.com create the kitchen of your dreams.
I would agree that more of the properties could be made available to the user (tntdavid: look at the DefaultFurnitureCatalog.PropertyKey) price being one (+ creator and more).
However, in your case, there is a possibility to communicate with the user of an imported library using the property information: information#1=<font color="RED"><a href="http://www.composant-dynamique.com" >Kitchen model EURO 56</a></font> This provides extra information in the Furniture Catalogue view and - as the example shows - even lets you link to where you can find the item.
Maybe I am missing something, but I have not found a way of making these properties visible in the Home Furniture List. And that I think could be very useful. Especially as this list is so easy to copy and paste into a spreadsheet, it would be very easy to calculate total cost of all items.
As for the Furniture Library Editor, I don't think there is an Undo feature on the drawing board (see this post). I admit this has caused me some heartache too, but if you always work on copies and backup for every change, it is something I can live without. But - repeating myself - I would like as many properties as possible available when using the Editor. Simply because the detour of unzipping/opening the PluginFurnitureCatalog.properties and then reloading the catalogue, is distracting the process of creating objects.
Now, all these issues are, I believe in the wish-list / feature requests, and I feel a bit guilty for discussing them again. After all, whenever eTeks releases new versions, one can tell that careful consideration has gone into the priorities.
But yes, these features would be very welcome also for me. And the good news is, that SH3D is clearly designed for such future capabilities.
The priority absolute for me is to make visible the price of the 3D objects. Sweet home will be from then on, the best free 3D software for cuisinistes and many other Building trade. If this function does not go out to the next version, the biggest sccès will then be put back.
Prices management is already more or less programmed in Sweet Home 3D and the Furniture Library Editor, but I don't feel like activating this feature in the default release.
I must be missing something, because I am not sure I see the problem with lots of fields as long as the default furniture list does not reveal more than Name_Width_Depth_Height_Visible. What I think would be nice, though, is for the information# field to be carried over into the furniture list. That way I could look at the items from the plan - that is, with the hyperlink - without having to look up the original catalogue entry. ok
