You shouldn’t edit the libraries stored in private folders of Sweet Home 3D while you use Sweet Home 3D itself. I wonder if it was your case.
United States
It wasn't but that's okay for now. I had to set my computer back to factory in order to reinstall SH3D and have it work. Going to be far more careful from here on out.
Awesome, tool.
I would be forever greatful if you would add a direct or batch import from a website like 3dwarehouse.
It would be so nice to not have to download each model, unzip it, and import it individually.
When building a custom model library you may need hundreds of models and cutting all these steps out of the process would make it so much easier.
I was thinking maybe a search box, and the results have a thumbnail with hover to expand, a short description, and a checkbox to mark items you want to import.
This would speed up library creation greatly, and I believe would be well worth the effort.
Let me know if there is anything I can do to help.
Some time ago, I asked in SketchUp forum whether there was a way to explore and download the 3D models they propose on 3D Warehouse from a program, but I never got an answer Nevertheless, I tried on my side and found how to do it. But now, Trimble permits to download 3D models only by registered users, probably meaning that they want to limit this traffic. Maybe waking up the subject I started in SketchUp to get an official answer could help to get an official answer.
@Puybaret, Indeed, I use Sketchup in parallel with SH3D to create the furniture I need, and to connect to the 3D Warehouse / Trimble you must be registered...
Egypt
Thank you very much for the great tool, but may I as to add a preview section when selecting any obj. instead of hovering the mouse over the image to show and also will be useful to preview items when scrolling with keyboard arrows.
Interesting feature for those who use the latest version with the added description field: You can use html tags in the description!
This allows to make a part of the description bold or cursive with the b and i tags or add a line break (br). I use it to add the library name in bold followed by a line-break if there is more description info.
The version 2.0 of Furniture Library Editor is on its way, and I would like you to test a Beta version before releasing it. Its preferences pane was updated to let you add your own typed properties, and set whether each property should be modifiable and displayed in the furniture list of the editor. The list of furniture properties contain also the ones known in Sweet Home 3D like light properties and door/window properties, to let you choose whether you want to modify them or not in the modification dialog box of each piece of furniture.
Modifiable properties then appear in the furniture modification dialog box to let you set their values. Some known properties like price or resizable will appear as additional fields or check boxes, and other properties will appear in the new Additional properties table:
The properties with an Image type, like icon and planIcon in the previous screenshot, will be displayed as a button in their Value column to let you choose the image file of your choice. When the icon property is made modifiable in the preferences panel, you'll be able to choose an image with this button instead of a screenshot of the 3D preview.
The Editor will check whether values entered in the table for Sweet Home 3D known properties are valid, for example if the value of door sashes properties doorOrWindowSashXAxis, doorOrWindowSashYAxis, doorOrWindowSashWidth, doorOrWindowSashStartAngle and doorOrWindowSashEndAngle each contain 2 numbers if you want to define 2 sashes. Finally, the value of the following properties must contains lengths expressed in the current unit that the Editor will convert in centimeter in the SH3F file: doorOrWindowWallThickness doorOrWindowWallDistance doorOrWindowSashXAxis doorOrWindowSashYAxis doorOrWindowSashWidth lightSourceX lightSourceY lightSourceZ lightSourceDiameter dropOnTopElevation shelfElevations shelfBoxes
Hope you'll like it
[Note: Final version of Furniture Library Editor 2.0 was released on 09/22/2023]
[Edit 1 times,
last edit by Puybaret at Sep 22, 2023, 5:47:10 PM]
Great! A first test shows everything working fine. This will make fine-tuning specific values so much easier. Little changes to sashes or a cutout shape to get them correct can now be made much easier and faster.
Again I can scratch multiple items I have on my wishlist even without having asked for them on the forum
I tested the light properties. The link between those that are optional and those that are mandatory is coherent. This new option can be a great help for those who are not comfortable with editing the PluginFurnitureCatalog.properties file.
As far as I'm concerned, I would like to be able to add a unmodifiable property because my lights use the description property so that they are recognized by the photo plug-in.
EnkoNyito
