I don’t know what you saw but the Furniture Library Editor is a separated application as explained in the first message of this thread.
Russia
Hello! I would really like it to be possible to edit and save the price in the FurnitureLibraryEditor, so that when importing in the library, the price is linked to the model! Is there a way to do this? Our company is ready to pay for it, how much will it cost?
Hello Andrew,
You'll find a version with the additional Price / VAT / Resizable / Texturable fields in FurnitureLibraryEditorWithPrice-1.28.jarversion 2.0.
I also added Resizable and Texturable check boxes which prevents from resizing an object and changing its color / texture in Sweet Home 3D, when unchecked. If you want to preset the price of an object, I guess it's for real products which can't be resized or colored, right? I would be happy to know your actual use case.
The management of these fields was already programmed but disabled in the default version. If you like it, I'll add a Price option in the preferences of a future version of the Furniture Library Editor to enable them and avoid keeping this special version.
[Edit 1 times,
last edit by Puybaret at Sep 24, 2023, 3:20:14 PM]
[luigi@localhost burla]$ java -jar FurnitureLibraryEditor-1.28.jar Exception in thread "main" java.lang.reflect.InvocationTargetException at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:566) at com.eteks.furniturelibraryeditor.FurnitureLibraryEditorBootstrap.main(Unknown Source) Caused by: java.lang.UnsatisfiedLinkError: Can't load library: /usr/lib/jvm/java-11-openjdk-11.0.14.1.1-5.fc35.x86_64/lib/libawt_xawt.so at java.base/java.lang.ClassLoader.loadLibrary(ClassLoader.java:2630) at java.base/java.lang.Runtime.load0(Runtime.java:768) at java.base/java.lang.System.load(System.java:1837) at java.base/java.lang.ClassLoader$NativeLibrary.load0(Native Method) at java.base/java.lang.ClassLoader$NativeLibrary.load(ClassLoader.java:2442) at java.base/java.lang.ClassLoader$NativeLibrary.loadLibrary(ClassLoader.java:2498) at java.base/java.lang.ClassLoader.loadLibrary0(ClassLoader.java:2694) at java.base/java.lang.ClassLoader.loadLibrary(ClassLoader.java:2648) at java.base/java.lang.Runtime.loadLibrary0(Runtime.java:830) at java.base/java.lang.System.loadLibrary(System.java:1873) at java.desktop/java.awt.Toolkit$3.run(Toolkit.java:1399) at java.desktop/java.awt.Toolkit$3.run(Toolkit.java:1397) at java.base/java.security.AccessController.doPrivileged(Native Method) at java.desktop/java.awt.Toolkit.loadLibraries(Toolkit.java:1396) at java.desktop/java.awt.Toolkit.<clinit>(Toolkit.java:1429) at java.desktop/javax.swing.UIManager.getSystemLookAndFeelClassName(UIManager.java:661) at com.eteks.furniturelibraryeditor.FurnitureLibraryEditor.initLookAndFeel(Unknown Source) at com.eteks.furniturelibraryeditor.FurnitureLibraryEditor.init(Unknown Source) at com.eteks.furniture
I think you should reinstall Java or reuse the java command found in the runtime/bin subfolder of SweetHome3D installation folder.
