Total posts in this thread: 252
Posts: 252   Pages: 26   [ Previous Page | 13 14 15 16 17 18 19 20 21 22 | Next Page ]
Previous Thread This topic has been viewed 1398795 times and has 251 replies Next Thread
enkonyito
For building the FurnitureLibraryEditor-version.jar file with the furnitureLibraryEditorJarExecutable target, the Color button does not open any panel and displays this message in the command prompt:
Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: input == null!
at javax.imageio.ImageIO.read(Unknown Source)
at com.eteks.sweethome3d.swing.SwingTools.createCustomCursor(Unknown Source)
at com.eteks.sweethome3d.swing.ColorButton$RecentColorsPanel.<init>(Unknown Source)
at com.eteks.sweethome3d.swing.ColorButton.createColorChooser(Unknown Source)
at com.eteks.sweethome3d.swing.ColorButton.access$300(Unknown Source)
at com.eteks.sweethome3d.swing.ColorButton$2.actionPerformed(Unknown Source)
at com.eteks.furniturelibraryeditor.swing.ModelLightSourcesComponent$ModelLightSourcesPanel.displayView(Unknown Source)
at com.eteks.furniturelibraryeditor.swing.ModelLightSourcesComponent$1.actionPerformed(Unknown Source)
at com.eteks.sweethome3d.swing.SwingTools.showOptionDialog(Unknown Source)
at com.eteks.sweethome3d.swing.SwingTools.showConfirmDialog(Unknown Source)
at com.eteks.furniturelibraryeditor.swing.FurniturePanel.displayView(Unknown Source)
at com.eteks.furniturelibraryeditor.viewcontroller.FurnitureController.displayView(Unknown Source)
at com.eteks.furniturelibraryeditor.viewcontroller.FurnitureLibraryController.modifySelectedFurniture(U
nknown Source)
at com.eteks.furniturelibraryeditor.swing.FurnitureLibraryTable$3.mouseClicked(Unknown Source)
In Eclipse, the Color button opens the color modification panel.
EnkoNyito
[Edit 1 times, last edit by enkonyito at Sep 3, 2021, 4:49:58 PM]
[Sep 2, 2021, 3:12:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Many files of Sweet Home 3D are excluded from the JAR executable file of the Furniture Library Editor, to build a JAR file as small as possible.
If you change the features of the editor, you'll have to check which files you should not exclude anymore. In your case, I guess you need the pipette cursor icons found in com/eteks/sweethome3d/swing/resources/cursors folder.
[Sep 4, 2021, 9:32:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Indeed, the problem is solved by including the pipette cursor icons.
Here is the derived version that allows to create lights and modify their sources.
FurnitureLibraryEditor-1.28_derived.jar
FurnitureLibraryEditor-1.28-src_derived.zip
Note: As it is not possible to attach the files because apparently their sizes exceed the maximum allowed, I put links to SourceForge.
EnkoNyito
[Edit 2 times, last edit by enkonyito at Sep 5, 2021, 10:53:35 PM]
[Sep 5, 2021, 10:17:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
harbinger
US
The derived version works well, but i'm leery of those icons. Yuk!
Would be great if the light editor would draw where the light source is in relation to the model, using the XYZ we enter. I love the fact that i can adjust the color right there!
[Sep 20, 2021, 2:39:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@harbinger
The standard version of the FurnitureLibraryEditor-1.28 tool uses the new icons of Sweet Home 3D 6.6 .
It would be interesting but this problem does not yet have a solution.
EnkoNyito
[Sep 20, 2021, 5:35:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
davidzhghenti
Georgia
Good day all..
I download this program... In YouTube I saw Up panel is "Tools". near the File, EDIT, Plan, Help. in this How I add "TOOL"?
thanks,,,
[Oct 23, 2021, 8:10:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I don’t know what you saw but the Furniture Library Editor is a separated application as explained in the first message of this thread.
[Oct 23, 2021, 10:16:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
FurnitureLibraryEditor-1.28.1_derived
  • added light sources 3D preview (transparent light, opaque source)
executable jar
source code
EnkoNyito
[Oct 27, 2021, 11:11:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Andrew_Somovo
Russia
Hello! I would really like it to be possible to edit and save the price in the FurnitureLibraryEditor, so that when importing in the library, the price is linked to the model! Is there a way to do this? Our company is ready to pay for it, how much will it cost?
[Dec 1, 2021, 5:57:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hello Andrew,
You'll find a version with the additional Price / VAT / Resizable / Texturable fields in
FurnitureLibraryEditorWithPrice-1.28.jar version 2.0.
I also added Resizable and Texturable check boxes which prevents from resizing an object and changing its color / texture in Sweet Home 3D, when unchecked. If you want to preset the price of an object, I guess it's for real products which can't be resized or colored, right? I would be happy to know your actual use case.
The management of these fields was already programmed but disabled in the default version.
If you like it, I'll add a Price option in the preferences of a future version of the Furniture Library Editor to enable them and avoid keeping this special version.
[Edit 1 times, last edit by Puybaret at Sep 24, 2023, 3:20:14 PM]
[Dec 1, 2021, 10:24:56 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
