There's no separated version history for the Furniture Library Editor. The version 1.28 only brought some icon changes.
For building the FurnitureLibraryEditor-version.jar file with the furnitureLibraryEditorJarExecutable target, the Color button does not open any panel and displays this message in the command prompt:
Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: input == null! at javax.imageio.ImageIO.read(Unknown Source) at com.eteks.sweethome3d.swing.SwingTools.createCustomCursor(Unknown Source) at com.eteks.sweethome3d.swing.ColorButton$RecentColorsPanel.<init>(Unknown Source) at com.eteks.sweethome3d.swing.ColorButton$RecentColorsPanel.<init>(Unknown Source) at com.eteks.sweethome3d.swing.ColorButton.createColorChooser(Unknown Source) at com.eteks.sweethome3d.swing.ColorButton.access$300(Unknown Source) at com.eteks.sweethome3d.swing.ColorButton$2.actionPerformed(Unknown Source) ... at com.eteks.furniturelibraryeditor.swing.ModelLightSourcesComponent$ModelLightSourcesPanel.displayView(Unknown Source) at com.eteks.furniturelibraryeditor.swing.ModelLightSourcesComponent$1.actionPerformed(Unknown Source) ... at com.eteks.sweethome3d.swing.SwingTools.showOptionDialog(Unknown Source) at com.eteks.sweethome3d.swing.SwingTools.showConfirmDialog(Unknown Source) at com.eteks.furniturelibraryeditor.swing.FurniturePanel.displayView(Unknown Source) at com.eteks.furniturelibraryeditor.viewcontroller.FurnitureController.displayView(Unknown Source) at com.eteks.furniturelibraryeditor.viewcontroller.FurnitureLibraryController.modifySelectedFurniture(U nknown Source) at com.eteks.furniturelibraryeditor.swing.FurnitureLibraryTable$3.mouseClicked(Unknown Source)
In Eclipse, the Color button opens the color modification panel.
EnkoNyito
[Edit 1 times,
last edit by enkonyito at Sep 3, 2021, 4:49:58 PM]
Many files of Sweet Home 3D are excluded from the JAR executable file of the Furniture Library Editor, to build a JAR file as small as possible. If you change the features of the editor, you'll have to check which files you should not exclude anymore. In your case, I guess you need the pipette cursor icons found in com/eteks/sweethome3d/swing/resources/cursors folder.
Note: As it is not possible to attach the files because apparently their sizes exceed the maximum allowed, I put links to SourceForge.
EnkoNyito
[Edit 2 times,
last edit by enkonyito at Sep 5, 2021, 10:53:35 PM]
US
The derived version works well, but i'm leery of those icons. Yuk!
Would be great if the light editor would draw where the light source is in relation to the model, using the XYZ we enter. I love the fact that i can adjust the color right there!
@harbinger
The standard version of the FurnitureLibraryEditor-1.28 tool uses the new icons of Sweet Home 3D 6.6 .
It would be interesting but this problem does not yet have a solution.
EnkoNyito
I don’t know what you saw but the Furniture Library Editor is a separated application as explained in the first message of this thread.
Russia
Hello! I would really like it to be possible to edit and save the price in the FurnitureLibraryEditor, so that when importing in the library, the price is linked to the model! Is there a way to do this? Our company is ready to pay for it, how much will it cost?
