This sounds a little like bug #684 but I don't remember someone reporting it for the Furniture Library Editor. Depending on your system, try to turn off Nahimic service or MSI afterburner / Riva Turner / Discord / NVidia Experience monitoring display software.
About editing furniture libraries with a text editor, read the More editing: PluginFurnitureCatalog.properties section in this document.
Germany
Hello and thanks for your help!
The main program is working fine for me (as do other programs like Blender, Sims 2 and such) it's just this one with a problem. I checked out the link to the bug and tried some things uninstalled java completely, restarted and reinstalled but that didn't change anything. I also checked the permissions for those files and the folder everything is in and I have full access to everything (just saying since win10 loves to make problems there). I can't find any of the things mentioned there (or by you) on my computer I checked the task processes and tried turning everything off that could be it but still no change I have a Intel(R) HD Graphics 4600 and Realtek High Definition Audio (Realtek HD Audio-Manager) and NVIDIA DDS Utilities. I'm not sure what else to try, if it were the main programm I could use compability mode but with a java app I can't select anything like that.
I also just realized this only happens with a library being open. -If the program is just started everything is fine. -If I add one or more objects its' fine. -If I save those objects into a library the problem is back. Don't even have to reopen it, just saving it as a library breaks the program. (I also tried with unchanged libraries that I downloaded like Scopia, Klicker and Archibit giving the same problem)
The link how to edit the raw text is very useful and at least a backup method if I can't get this to run again thanks for that!
@Puybaret
For interested programmers, source code is committed in the FurnitureLibraryEditor SVN module separated from SweetHome3D one. Furniture Library Editor project is derived from Sweet Home 3D project and uses a similar MVC architecture. Project contains a README.TXT file with compilation directions.
Is there a javadoc to view online or download?
EnkoNyito
No but you could generate the javadoc if needed. Just look at the javadoc target in Sweet Home 3D project to see how.
RF
Good afternoon. Please tell me how to add a choice of language in the program settings. I translated the .properties files, inserted them into the program, but in the choice of language, all the same, only English and French. Thanks.
The list of languages supported by the editor is returned by the getSupportedLanguages method in FurnitureLibraryUserPreferences class. Just add the language code you want to the array returned by this method.
I just tried your target on my side and it worked with JDK 1.8. There were some errors because the classpath wasn't complete but FurnitureLibraryEditor-1.28-javadoc.zip was generated and usable.
By modifying the source code, I was able to add 2 new properties (LIGHT and LIGHT_SOURCES). This adds a 'Light' column and a 'Light sources' button. FurnitureLibraryEditor-1.28_derived.jpg
For certain color (#44371B), this one is not taken into account in the PluginFurnitureCatalog.properties file and the console returns the message
java.lang.NumberFormatException: For input string: "FF44371B"
when the library created is imported back into the editor.
EnkoNyito
