Total posts in this thread: 252
Posts: 252   Pages: 26   [ Previous Page | 7 8 9 10 11 12 13 14 15 16 | Next Page ]
Previous Thread This topic has been viewed 1465370 times and has 251 replies Next Thread
You could try to use the same properties as the ones proposed for Sweet Home 3D.
To run a Jar executable with these properties, you don't need a .ini file but rather directly cite these properties after java :
java -Dcom.eteks.sweethome3d.resolutionScale=2 -Dswing.defaultlaf=javax.swing.plaf.metal.MetalLookAndFeel -Dswing.plaf.metal.controlFont=Dialog-11 -Dswing.plaf.metal.userFont=SansSerif-11 -Dswing.plaf.metal.systemFont=SansSerif-11 -jar path/to/FurnitureLibraryEditor-1.21.jar
The problem with this solution is that the resolution scale won't influence the height of rows in the table of the editor, so text in the table might be cut for a high value.
As Java 9 is supposed to have fixed problems with HiDPI screens, it might be interesting to give it a try too. If it works correctly, then no need of any option, just double click on FurnitureLibraryEditor-1.21.jar file.
[Oct 24, 2017, 3:11:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
captainstarbuck
I recently installed SW3D for the first time and created a model of our house. Love it! Thank you VERY much!
Running SW3D 5.6, JRE 1.9, Windows 8.1
Now I'm importing SH3F files from various sources, like furniture stores that provide models. After downloading hundreds of these files I found I was unable to use the default Import feature to import more than one file. So I ZIPped the files, and while the UI refreshes and says new objects were were imported, that's never the case.
So I found the FLE here, downloaded v1.21, and while it does accept multiple files, it doesn't import the data to SW3D with the same detail as just opening a .SH3F file.
So as a user I'd like to know if I'm missing anything, and how I can import hundreds of files (with FLE?) without doing it one at a time.
As a developer, I'm happy to do some diagnostics and even (with very limited time) get into code to try to help with this.
For an example of files that import differently, see the M2Italia furniture site.
Thanks!!
[Jan 6, 2018, 5:53:28 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
To import many 3D model files at once in the Furniture Library Editor, just select multiple files and drag and drop them on the main window of the editor.
If you want to create one SH3F file from other SH3F files you should use the Merge button. Unfortunately the file dialog won't allow you to import more than a SH3F file at a time in that case, but this could be a nice improvement...
[Jan 7, 2018, 2:20:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Cleaning up libraries and shrinking models with an aim to have one compact library for all the models I know to be small and work.
Among those models are windows with several elements, such as a middle bar, that can be set to invisible. But for that I basically wish for two different sets of doorOrWindowSash....# properties for that one window. Or in other cases, I might want two different planIcons for one model (I prefer using semi transparent icons for staircases, awnings and ceiling lamps).
I was wondering how best to do this:
Is it possible/advisable to have several entries in PluginFurnitureCatalog.properties referencing one single model?
[Jan 30, 2018, 7:51:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Point was, I seem to remember that is how it is done with the light sources, but have a feeling it might not work as well with a mixed library with many models. ok
[Jan 30, 2018, 8:01:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If you want to change the visible parts of a given model, you should use different MTL files changing the transparency factor in d lines (d 0 being fully transparent and d 1 fully opaque). As the MTL file used by an OBJ file must be cited in its mtllib line, you won't have any other choice that creating different OBJ files.
But it's not a problem to have different pieces citing the same value in their model...# property and a different value in their planIcon...# or doorOrWindowSash....# properties. There was a bug in the Furniture Library Editor some time ago about this but it was fixed in version 1.20.
By the way, here's a version 1.22 of the editor with IDs if needed. I promise the choice of the columns editable in the editor will end up in preferences one day [edit: removed link, IDs can now be displayed with an option in preferences]
[Edit 1 times, last edit by Puybaret at Aug 10, 2022, 11:57:15 AM]
[Jan 30, 2018, 11:08:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for the reply.
Good, then my memory did not fail me completely.
..change the visible parts of a given model, you should use different MTL
Maybe I do not understand, or we are talking about different things. The d setting in .mtl, it will not help me get what I want. For instance: one model consisting of a door-frame + door, with different named colours in .obj/.mtl. I import one instance of the model and use throughout the home. Where I want the door left 'open', I change that door colour (but not frame) to invisible in the colour dialogue in SH3D. That way the frames remain and I can open and close doors by toggling the colour=invisible.
I will try a couple of options and see what works best. Thanks.
[Jan 30, 2018, 3:06:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
@okh I've use this feature and I've create some furniture for this.
You can try this door
https://sourceforge.net/p/sweethome3d/d-models/444/#10c5
Maybe someone could introduce this to make some animations when visit a home. When camera is near door the door start opening. Could be made it in AOI this kind of animation.
Off course only for those interested in this kind of virtual reality. I'm not!
Dorin
[Jan 31, 2018, 11:05:53 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for the file, Dorin. It is the same principle I use. Exploiting the set-to-invisible in the colour dialogue to hide/display construction elements e.g. for quick visualisation for a planning application: changing 30 plain windows to windows with glazing-bars. Quick to see just by hiding the glazing bar.
Using one model in different contexts can be handy, but sometimes I ponder whether it could make sense to make two catalogue entries for the same model; equip the model with different properties - for instance:
One set of properties:
name#1=Door glass 3p
model#1=/Door glass 3p/Door-glass-3p.obj
Then below, a seceond set of properties for the same model:
name#2=Door glass XXXXX2
model#2=/Door glass 3p/Door-glass-3p.obj
model#2=doorOrWindowSash....#.... etc
I have yet to decide whether this can be useful or confusing. Maybe for use with one staircase model but several entries: with different cutouts, with or without semi-transparent stair planIcon (I prefer being able to see through the stairs in the 2D plan, but not everyone would agree). ok
[Jan 31, 2018, 1:27:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
From my point of view I prefer to have more options to modify an object in contextual menu than to have 3 (or more) pretty the same furniture.
Maybe in property file to have predefined few variants and in modify furniture to chose which to display. In my case 0;45;90 degrees open.
Also for modify the cutoff in Your case.
Now is about 1000 furniture on official and at least 1000 unofficial which are used for most of us. To have 4~6000 in the library I don't think is useful.
Is only an opinion.
[Feb 14, 2018, 10:21:06 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
