Re: Sweet Home 3D 2.4
db4:
As per your instructions, I did exactly what you asked, and, lo and behold, SH3D displays on my laptop the same quirky behaviour as you described. The vertical divider moves from approx. the left of F5 to the right of F6.
Today's update brings some big improvements on memory usage, and better performances for some DAE/Collada files.
By the way, I noticed that the improvements on memory usage speed up the performances of 3DS files imported from ZIP files, when you move or rotate them.
I fixed the growing catalog view bug in Sweet Home 3D 2.4 Beta 5. Thank you db4tech for your detailed description. It helped to fix this bug.
Sorry, it was fixed in source code repository, but I made an error when I released the Beta 5. It's correct in Sweet Home 3D 2.4 Beta 6 now.
I can indeed confirm that the bug is now fixed.
While you are getting ready for your next release when you get chance you'll have to update your splash screen, replacing the old style TV for a new LCD TV, the up-lighter can now be illuminated and atmospheric lighting could be added (drawing attention to the new lighting capabilities) oh! Also don't forget to change the date to 2007-2010
Nice image db4tech!
I released version 2.4 tonight. I'll have to update Advanced rendering plug-in.
Emmanuel:
Maybe I'm too quick with this post of my test with v2.4.
From left to right: - The standard render in the 3D pane - The "old" photo render - The new Phong render (all 3 plug-ins have this problem)
The gentlemen are zip-files from the Google Sketchup library in the Collada file format.
Nevertheless, you've done a terrific job once again!
[Edit 1 times,
last edit by hansmex at May 26, 2010, 1:37:42 AM]
