matstardust
ubuntu lucid problem
hi guys, I've a problem with ubuntu lucid and SWH3d 2.3. When I click on SweetHome3D script, I get the following error message: # # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0x6fc01ef6, pid=13017, tid=1872989040 # # JRE version: 6.0_18-b07 # Java VM: Java HotSpot(TM) Client VM (16.0-b13 mixed mode linux-x86 ) # Problematic frame: # C [libGL.so.1+0x65ef6] XF86DRIQueryExtension+0x8e # # An error report file with more information is saved as: # /tmp/hs_err_pid13017.log # # If you would like to submit a bug report, please visit: # http://java.sun.com/webapps/bugreport/crash.jsp # The crash happened outside the Java Virtual Machine in native code. # See problematic frame for where to report the bug. Could you help me to resolve the problem? I'll attached the log file. Thanks # # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0x6fc01ef6, pid=13017, tid=1872989040 # # JRE version: 6.0_18-b07 # Java VM: Java HotSpot(TM) Client VM (16.0-b13 mixed mode linux-x86 ) # Problematic frame: # C [libGL.so.1+0x65ef6] XF86DRIQueryExtension+0x8e # # If you would like to submit a bug report, please visit: # http://java.sun.com/webapps/bugreport/crash.jsp # The crash happened outside the Java Virtual Machine in native code. # See problematic frame for where to report the bug. # --------------- T H R E A D --------------- Current thread (0x09bcf400): JavaThread "J3D-Renderer-1" [_thread_in_native, id=13039, stack(0x6f9e8000,0x6fa39000)] siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR), si_addr=0x00000004 Registers: EAX=0x00000041, EBX=0x09baa728, ECX=0x09bb3b60, EDX=0x6fc4ed60 ESP=0x6fa35b54, EBP=0x09bd3198, ESI=0x00000000, EDI=0x00000001 EIP=0x6fc01ef6, CR2=0x00000004, EFLAGS=0x00210202 Top of Stack: (sp=0x6fa35b54) 0x6fa35b54: b76689ae b766aecd 00000000 00000000 0x6fa35b64: 0000000d 00000078 6fa35b8c 0000000d 0x6fa35b74: 00000064 00000001 09bd3198 00002000 0x6fa35b84: 09bd04ec 6fbff5d0 09bd3198 6fa35bd0 0x6fa35b94: 6fa35bd4 b77523c0 00000020 b77523f0 0x6fa35ba4: b7750ff4 b77523c0 6fa37bfc 09bd04d0 0x6fa35bb4: b766a93c 09bd04d0 b76298cf 6fc2d0dc 0x6fa35bc4: 6fa37bfc b77523c0 6fc2d0de 00000013 Instructions: (pc=0x6fc01ef6) 0x6fc01ee6: 00 66 89 79 02 83 45 6c 04 83 45 60 01 8b 76 08 0x6fc01ef6: 0f b6 56 04 88 11 88 41 01 33 c9 8d 04 24 51 51 Stack: [0x6f9e8000,0x6fa39000], sp=0x6fa35b54, free space=1366fa354e0k Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code) C [libGL.so.1+0x65ef6] XF86DRIQueryExtension+0x8e Java frames: (J=compiled Java code, j=interpreted, Vv=VM code) j javax.media.j3d.X11NativeScreenInfo.queryGLX13(J)Z+0 j javax.media.j3d.X11NativeScreenInfo.isGLX13()Z+13 j javax.media.j3d.X11NativeConfigTemplate3D.getBestConfiguration(Ljavax/media/j3d/GraphicsConfigTemplate3D;[Ljava/awt/GraphicsConfiguration;)Ljava/awt/GraphicsConfiguration;+13 j javax.media.j3d.NativePipeline.getBestConfiguration(Ljavax/media/j3d/GraphicsConfigTemplate3D;[Ljava/awt/GraphicsConfiguration;)Ljava/awt/GraphicsConfiguration;+5 j javax.media.j3d.Renderer.doWork(J)V+1466 j javax.media.j3d.J3dThread.run()V+19 v ~StubRoutines::call_stub --------------- P R O C E S S --------------- Java Threads: ( => current thread ) =>0x09bcf400 JavaThread "J3D-Renderer-1" [_thread_in_native, id=13039, stack(0x6f9e8000,0x6fa39000)] 0x09bcb800 JavaThread "J3D-MasterControl-1" [_thread_blocked, id=13038, stack(0x6fa39000,0x6fa8a000)] 0x09bd8000 JavaThread "J3D-NotificationThread" [_thread_blocked, id=13037, stack(0x6fa8a000,0x6fadb000)] 0x09bdc000 JavaThread "J3D-TimerThread" [_thread_blocked, id=13036, stack(0x6fadb000,0x6fb2c000)] 0x09bd9c00 JavaThread "J3D-RenderingAttributesStructureUpdateThread" [_thread_blocked, id=13035, stack(0x6fb2c000,0x6fb7d000)] 0x09b83400 JavaThread "pool-2-thread-1" [_thread_in_native, id=13034, stack(0x6fc74000,0x6fcc5000)] 0x09b7c000 JavaThread "pool-1-thread-1" [_thread_blocked, id=13033, stack(0x6fd14000,0x6fd65000)] 0x09b76400 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=13032, stack(0x6fd65000,0x6fdb6000)] 0x09b75400 JavaThread "AWT-Shutdown" [_thread_blocked, id=13031, stack(0x6fe14000,0x6fe65000)] 0x09b68400 JavaThread "AWT-XAWT" daemon [_thread_in_native, id=13030, stack(0x6fe65000,0x6feb6000)] 0x09b01400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=13029, stack(0x6ffa0000,0x6fff1000)] 0x09a50800 JavaThread "Timer-0" daemon [_thread_blocked, id=13028, stack(0x7026e000,0x702bf000)] 0x099d1800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=13026, stack(0x703c2000,0x70413000)] 0x099cfc00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=13025, stack(0x70413000,0x70494000)] 0x099ce400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=13024, stack(0x70494000,0x704e5000)] 0x099bac00 JavaThread "Finalizer" daemon [_thread_blocked, id=13023, stack(0x7052b000,0x7057c000)] 0x099b9400 JavaThread "Reference Handler" daemon [_thread_blocked, id=13022, stack(0x7057c000,0x705cd000)] 0x0996f000 JavaThread "main" [_thread_blocked, id=13020, stack(0xb6cc3000,0xb6d14000)] Other Threads: 0x099b6800 VMThread [stack: 0x705cd000,0x7064e000] [id=13021] 0x099d5400 WatcherThread [stack: 0x70341000,0x703c2000] [id=13027] VM state:not at safepoint (normal execution) VM Mutex/Monitor currently owned by a thread: None Heap def new generation total 4800K, used 3985K [0x70bb0000, 0x710e0000, 0x86100000) eden space 4288K, 88% used [0x70bb0000, 0x70f69548, 0x70fe0000) from space 512K, 33% used [0x70fe0000, 0x7100b080, 0x71060000) to space 512K, 0% used [0x71060000, 0x71060000, 0x710e0000) tenured generation total 10752K, used 1215K [0x86100000, 0x86b80000, 0xb0bb0000) the space 10752K, 11% used [0x86100000, 0x8622fd88, 0x8622fe00, 0x86b80000) compacting perm gen total 12288K, used 9883K [0xb0bb0000, 0xb17b0000, 0xb4bb0000) the space 12288K, 80% used [0xb0bb0000, 0xb1556e40, 0xb1557000, 0xb17b0000) No shared spaces configured. Dynamic libraries: 08048000-08052000 r-xp 00000000 08:02 794522 /opt/SweetHome3D-2.3/jre1.6.0_18/bin/java 08052000-08053000 rwxp 00009000 08:02 794522 /opt/SweetHome3D-2.3/jre1.6.0_18/bin/java 09969000-09c27000 rwxp 00000000 00:00 0 [heap] 6f9e8000-6f9eb000 ---p 00000000 00:00 0 6f9eb000-6fa39000 rwxp 00000000 00:00 0 [threadstack:0004d494] 6fa39000-6fa3c000 ---p 00000000 00:00 0 6fa3c000-6fa8a000 rwxp 00000000 00:00 0 6fa8a000-6fa8d000 ---p 00000000 00:00 0 6fa8d000-6fadb000 rwxp 00000000 00:00 0 6fadb000-6fade000 ---p 00000000 00:00 0 6fade000-6fb2c000 rwxp 00000000 00:00 0 6fb2c000-6fb2f000 ---p 00000000 00:00 0 6fb2f000-6fb7d000 rwxp 00000000 00:00 0 6fb7d000-6fb9a000 r-xp 00000000 08:02 788025 /lib/libgcc_s.so.1 6fb9a000-6fb9b000 r-xp 0001c000 08:02 788025 /lib/libgcc_s.so.1 6fb9b000-6fb9c000 rwxp 0001d000 08:02 788025 /lib/libgcc_s.so.1 6fb9c000-6fc43000 r-xp 00000000 08:02 673535 /usr/lib/fglrx/libGL.so.1.2 6fc43000-6fc4d000 rwxp 000a7000 08:02 673535 /usr/lib/fglrx/libGL.so.1.2 6fc4d000-6fc52000 rwxp 00000000 00:00 0 6fc52000-6fc73000 r-xp 00000000 08:02 795460 /opt/SweetHome3D-2.3/lib/libj3dcore-ogl.so 6fc73000-6fc74000 rwxp 00021000 08:02 795460 /opt/SweetHome3D-2.3/lib/libj3dcore-ogl.so 6fc74000-6fc77000 ---p 00000000 00:00 0 6fc77000-6fcc5000 rwxp 00000000 00:00 0 6fcc5000-6fd14000 rwxs 00000000 00:04 5931023 /SYSV00000000 (deleted) 6fd14000-6fd17000 ---p 00000000 00:00 0 6fd17000-6fd65000 rwxp 00000000 00:00 0 6fd65000-6fd68000 ---p 00000000 00:00 0 6fd68000-6fdb6000 rwxp 00000000 00:00 0 6fdb6000-6fdb7000 r-xs 00000000 08:02 137486 /var/cache/fontconfig/c05880de57d1f5e948fdfacc138775d9-le32d4.cache-3 6fdb7000-6fdbd000 r-xs 00000000 08:02 137389 /var/cache/fontconfig/945677eb7aeaf62f1d50efc3fb3ec7d8-le32d4.cache-3 6fdbd000-6fdbf000 r-xs 00000000 08:02 137481 /var/cache/fontconfig/99e8ed0e538f840c565b6ed5dad60d56-le32d4.cache-3 6fdbf000-6fdc2000 r-xs 00000000 08:02 137478 /var/cache/fontconfig/e383d7ea5fbe662a33d9b44caf393297-le32d4.cache-3 6fdc2000-6fdc3000 r-xs 00000000 08:02 137470 /var/cache/fontconfig/e7071f4a29fa870f4323321c154eba04-le32d4.cache-3 6fdc3000-6fdc6000 r-xs 00000000 08:02 137467 /var/cache/fontconfig/6eb3985aa4124903f6ff08ba781cd364-le32d4.cache-3 6fdc6000-6fdc7000 r-xs 00000000 08:02 137461 /var/cache/fontconfig/4c73fe0c47614734b17d736dbde7580a-le32d4.cache-3 6fdc7000-6fdc8000 r-xs 00000000 08:02 137456 /var/cache/fontconfig/0d8c3b2ac0904cb8a57a757ad11a4a08-le32d4.cache-3 6fdc8000-6fdc9000 r-xs 00000000 08:02 137454 /var/cache/fontconfig/6a53c69dea097a2d716e069445527da8-le32d4.cache-3 6fdc9000-6fdcd000 r-xs 00000000 08:02 137447 /var/cache/fontconfig/a755afe4a08bf5b97852ceb7400b47bc-le32d4.cache-3 6fdcd000-6fdd4000 r-xs 00000000 08:02 139737 /var/cache/fontconfig/6d41288fd70b0be22e8c3a91e032eec0-le32d4.cache-3 6fdd4000-6fddf000 r-xs 00000000 08:02 137442 /var/cache/fontconfig/0f34bcd4b6ee430af32735b75db7f02b-le32d4.cache-3 6fddf000-6fe01000 r-xs 00000000 08:02 140020 /var/cache/fontconfig/365b55f210c0a22e9a19e35191240f32-le32d4.cache-3 6fe14000-6fe17000 ---p 00000000 00:00 0 6fe17000-6fe65000 rwxp 00000000 00:00 0 6fe65000-6fe68000 ---p 00000000 00:00 0 6fe68000-6feb6000 rwxp 00000000 00:00 0 6feb6000-6feba000 r-xp 00000000 08:02 293298 /usr/lib/libXfixes.so.3.1.0 6feba000-6febb000 r-xp 00003000 08:02 293298 /usr/lib/libXfixes.so.3.1.0 6febb000-6febc000 rwxp 00004000 08:02 293298 /usr/lib/libXfixes.so.3.1.0 6febc000-6fec4000 r-xp 00000000 08:02 300745 /usr/lib/libXrender.so.1.3.0 6fec4000-6fec5000 r-xp 00007000 08:02 300745 /usr/lib/libXrender.so.1.3.0 6fec5000-6fec6000 rwxp 00008000 08:02 300745 /usr/lib/libXrender.so.1.3.0 6fec6000-6fece000 r-xp 00000000 08:02 300930 /usr/lib/libXcursor.so.1.0.2 6fece000-6fecf000 r-xp 00007000 08:02 300930 /usr/lib/libXcursor.so.1.0.2 6fecf000-6fed0000 rwxp 00008000 08:02 300930 /usr/lib/libXcursor.so.1.0.2 6fed4000-6fedb000 r-xp 00000000 08:02 673551 /usr/lib/fglrx/libatiuki.so.1.0 6fedb000-6fedc000 rwxp 00006000 08:02 673551 /usr/lib/fglrx/libatiuki.so.1.0 6fedc000-6fee3000 r-xs 00111000 08:02 795299 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/resources.jar 6fee3000-6ff62000 r-xp 00000000 08:02 794678 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/libfontmanager.so 6ff62000-6ff6d000 rwxp 0007e000 08:02 794678 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/libfontmanager.so 6ff6d000-6ff71000 rwxp 00000000 00:00 0 6ff71000-6ff9f000 r-xp 00000000 08:02 794693 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/libjpeg.so 6ff9f000-6ffa0000 rwxp 0002e000 08:02 794693 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/libjpeg.so 6ffa0000-6ffa3000 ---p 00000000 00:00 0 6ffa3000-6fff1000 rwxp 00000000 00:00 0 6fff1000-6fff5000 r-xp 00000000 08:02 292850 /usr/lib/libXdmcp.so.6.0.0 6fff5000-6fff6000 r-xp 00003000 08:02 292850 /usr/lib/libXdmcp.so.6.0.0 6fff6000-6fff7000 rwxp 00004000 08:02 292850 /usr/lib/libXdmcp.so.6.0.0 6fff7000-7000f000 r-xp 00000000 08:02 292852 /usr/lib/libxcb.so.1.1.0 7000f000-70010000 r-xp 00017000 08:02 292852 /usr/lib/libxcb.so.1.1.0 70010000-70011000 rwxp 00018000 08:02 292852 /usr/lib/libxcb.so.1.1.0 70011000-7001d000 r-xp 00000000 08:02 293310 /usr/lib/libXi.so.6.1.0 7001d000-7001e000 r-xp 0000c000 08:02 293310 /usr/lib/libXi.so.6.1.0 7001e000-7001f000 rwxp 0000d000 08:02 293310 /usr/lib/libXi.so.6.1.0 7001f000-70023000 r-xp 00000000 08:02 305540 /usr/lib/libXtst.so.6.1.0 70023000-70024000 r-xp 00003000 08:02 305540 /usr/lib/libXtst.so.6.1.0 70024000-70025000 rwxp 00004000 08:02 305540 /usr/lib/libXtst.so.6.1.0 70025000-7013e000 r-xp 00000000 08:02 293113 /usr/lib/libX11.so.6.3.0 7013e000-7013f000 r-xp 00118000 08:02 293113 /usr/lib/libX11.so.6.3.0 7013f000-70141000 rwxp 00119000 08:02 293113 /usr/lib/libX11.so.6.3.0 70141000-70142000 rwxp 00000000 00:00 0 70142000-70150000 r-xp 00000000 08:02 293119 /usr/lib/libXext.so.6.4.0 70150000-70151000 r-xp 0000d000 08:02 293119 /usr/lib/libXext.so.6.4.0 70151000-70152000 rwxp 0000e000 08:02 293119 /usr/lib/libXext.so.6.4.0 70152000-70155000 r-xs 00000000 08:02 137434 /var/cache/fontconfig/d60319d88cac85ba9e1a07bd06cfbb8c-le32d4.cache-3 70155000-7015d000 r-xs 00000000 08:02 135607 /var/cache/fontconfig/d52a8644073d54c13679302ca1180695-le32d4.cache-3 7015d000-7015f000 r-xs 00000000 08:02 137395 /var/cache/fontconfig/e13b20fdb08344e0e664864cc2ede53d-le32d4.cache-3 7015f000-70165000 r-xs 00000000 08:02 136530 /var/cache/fontconfig/531923aa54d0b5d0a874e3141e1499d8-le32d4.cache-3 70165000-701a8000 r-xp 00000000 08:02 794670 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/xawt/libmawt.so 701a8000-701aa000 rwxp 00043000 08:02 794670 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/xawt/libmawt.so 701aa000-701ab000 rwxp 00000000 00:00 0 701ab000-7022f000 r-xp 00000000 08:02 794673 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/libawt.so 7022f000-70236000 rwxp 00084000 08:02 794673 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/libawt.so 70236000-7025a000 rwxp 00000000 00:00 0 7025a000-7026d000 r-xp 00000000 08:02 794701 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/libnet.so 7026d000-7026e000 rwxp 00013000 08:02 794701 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/libnet.so 7026e000-70271000 ---p 00000000 00:00 0 70271000-702bf000 rwxp 00000000 00:00 0 702bf000-702c8000 r-xs 000bd000 08:02 795274 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/javaws.jar 702c8000-702ca000 r-xs 0004c000 08:02 795462 /opt/SweetHome3D-2.3/lib/vecmath.jar 702ca000-702d8000 r-xs 00193000 08:02 795457 /opt/SweetHome3D-2.3/lib/j3dutils.jar 702d8000-702e4000 r-xs 002c7000 08:02 795456 /opt/SweetHome3D-2.3/lib/j3dcore.jar 702e4000-702f2000 r-xs 000e1000 08:02 795458 /opt/SweetHome3D-2.3/lib/jmf.jar 702f2000-702f9000 r-xs 0004d000 08:02 795461 /opt/SweetHome3D-2.3/lib/sunflow-0.07.3c.jar 702f9000-70300000 r-xs 0006d000 08:02 795454 /opt/SweetHome3D-2.3/lib/freehep-vectorgraphics-svg-2.1.1.jar 70300000-7030c000 r-xs 00108000 08:02 795455 /opt/SweetHome3D-2.3/lib/iText-2.1.7.jar 7030c000-7031d000 r-xs 00308000 08:02 795450 /opt/SweetHome3D-2.3/lib/Help.jar 7031d000-70341000 r-xs 001aa000 08:02 795452 /opt/SweetHome3D-2.3/lib/SweetHome3D.jar 70341000-70342000 ---p 00000000 00:00 0 70342000-703c2000 rwxp 00000000 00:00 0 703c2000-703c5000 ---p 00000000 00:00 0 703c5000-70413000 rwxp 00000000 00:00 0 70413000-70416000 ---p 00000000 00:00 0 70416000-70494000 rwxp 00000000 00:00 0 70494000-70497000 ---p 00000000 00:00 0 70497000-704e5000 rwxp 00000000 00:00 0 704e5000-704ec000 r-xs 00000000 08:02 265294 /usr/lib/gconv/gconv-modules.cache 704ec000-7052b000 r-xp 00000000 08:02 273062 /usr/lib/locale/it_IT.utf8/LC_CTYPE 7052b000-7052e000 ---p 00000000 00:00 0 7052e000-7057c000 rwxp 00000000 00:00 0 7057c000-7057f000 ---p 00000000 00:00 0 7057f000-705cd000 rwxp 00000000 00:00 0 705cd000-705ce000 ---p 00000000 00:00 0 705ce000-70681000 rwxp 00000000 00:00 0 70681000-70818000 r-xs 02ab6000 08:02 795301 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/rt.jar 70818000-7081f000 rwxp 00000000 00:00 0 7081f000-70839000 rwxp 00000000 00:00 0 70839000-7083f000 rwxp 00000000 00:00 0 7083f000-7098f000 rwxp 00000000 00:00 0 7098f000-70992000 rwxp 00000000 00:00 0 70992000-70a39000 rwxp 00000000 00:00 0 70a39000-70a3f000 rwxp 00000000 00:00 0 70a3f000-70b8f000 rwxp 00000000 00:00 0 70b8f000-70b95000 rwxp 00000000 00:00 0 70b95000-70baf000 rwxp 00000000 00:00 0 70baf000-710e0000 rwxp 00000000 00:00 0 710e0000-86100000 rwxp 00000000 00:00 0 86100000-86b80000 rwxp 00000000 00:00 0 86b80000-b0bb0000 rwxp 00000000 00:00 0 b0bb0000-b17b0000 rwxp 00000000 00:00 0 b17b0000-b4bb0000 rwxp 00000000 00:00 0 b4bb1000-b4bb5000 rwxp 00000000 00:00 0 b4bb5000-b4c31000 rwxp 00000000 00:00 0 b4c31000-b4d29000 rwxp 00000000 00:00 0 b4d29000-b6c31000 rwxp 00000000 00:00 0 b6c31000-b6c40000 r-xp 00000000 08:02 794709 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/libzip.so b6c40000-b6c42000 rwxp 0000e000 08:02 794709 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/libzip.so b6c42000-b6c4c000 r-xp 00000000 08:02 788249 /lib/tls/i686/cmov/libnss_files-2.11.1.so b6c4c000-b6c4d000 r-xp 00009000 08:02 788249 /lib/tls/i686/cmov/libnss_files-2.11.1.so b6c4d000-b6c4e000 rwxp 0000a000 08:02 788249 /lib/tls/i686/cmov/libnss_files-2.11.1.so b6c4e000-b6c56000 r-xp 00000000 08:02 788251 /lib/tls/i686/cmov/libnss_nis-2.11.1.so b6c56000-b6c57000 r-xp 00007000 08:02 788251 /lib/tls/i686/cmov/libnss_nis-2.11.1.so b6c57000-b6c58000 rwxp 00008000 08:02 788251 /lib/tls/i686/cmov/libnss_nis-2.11.1.so b6c58000-b6c59000 r-xp 00000000 08:02 794691 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/libjawt.so b6c59000-b6c5a000 rwxp 00000000 08:02 794691 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/libjawt.so b6c5a000-b6c5d000 r-xs 00000000 08:02 140011 /var/cache/fontconfig/7ef2298fde41cc6eeb7af42e48b7d293-le32d4.cache-3 b6c5d000-b6c63000 r-xs 002c8000 08:02 795449 /opt/SweetHome3D-2.3/lib/Furniture.jar b6c63000-b6c6b000 rwxs 00000000 08:02 680551 /tmp/hsperfdata_matstardust/13017 b6c6b000-b6c7e000 r-xp 00000000 08:02 788246 /lib/tls/i686/cmov/libnsl-2.11.1.so b6c7e000-b6c7f000 r-xp 00012000 08:02 788246 /lib/tls/i686/cmov/libnsl-2.11.1.so b6c7f000-b6c80000 rwxp 00013000 08:02 788246 /lib/tls/i686/cmov/libnsl-2.11.1.so b6c80000-b6c82000 rwxp 00000000 00:00 0 b6c82000-b6c84000 r-xp 00000000 08:02 292844 /usr/lib/libXau.so.6.0.0 b6c84000-b6c85000 r-xp 00001000 08:02 292844 /usr/lib/libXau.so.6.0.0 b6c85000-b6c86000 rwxp 00002000 08:02 292844 /usr/lib/libXau.so.6.0.0 b6c86000-b6c8c000 r-xp 00000000 08:02 788247 /lib/tls/i686/cmov/libnss_compat-2.11.1.so b6c8c000-b6c8d000 r-xp 00006000 08:02 788247 /lib/tls/i686/cmov/libnss_compat-2.11.1.so b6c8d000-b6c8e000 rwxp 00007000 08:02 788247 /lib/tls/i686/cmov/libnss_compat-2.11.1.so b6c8e000-b6c94000 r-xp 00000000 08:02 794664 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/native_threads/libhpi.so b6c94000-b6c95000 rwxp 00006000 08:02 794664 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/native_threads/libhpi.so b6c95000-b6cb8000 r-xp 00000000 08:02 794686 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/libjava.so b6cb8000-b6cba000 rwxp 00023000 08:02 794686 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/libjava.so b6cba000-b6cc1000 r-xp 00000000 08:02 788256 /lib/tls/i686/cmov/librt-2.11.1.so b6cc1000-b6cc2000 r-xp 00006000 08:02 788256 /lib/tls/i686/cmov/librt-2.11.1.so b6cc2000-b6cc3000 rwxp 00007000 08:02 788256 /lib/tls/i686/cmov/librt-2.11.1.so b6cc3000-b6cc6000 ---p 00000000 00:00 0 b6cc6000-b6d14000 rwxp 00000000 00:00 0 b6d14000-b6d38000 r-xp 00000000 08:02 788244 /lib/tls/i686/cmov/libm-2.11.1.so b6d38000-b6d39000 r-xp 00023000 08:02 788244 /lib/tls/i686/cmov/libm-2.11.1.so b6d39000-b6d3a000 rwxp 00024000 08:02 788244 /lib/tls/i686/cmov/libm-2.11.1.so b6d3a000-b71bc000 r-xp 00000000 08:02 794656 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/client/libjvm.so b71bc000-b71dd000 rwxp 00482000 08:02 794656 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/client/libjvm.so b71dd000-b75fb000 rwxp 00000000 00:00 0 b75fb000-b774e000 r-xp 00000000 08:02 788240 /lib/tls/i686/cmov/libc-2.11.1.so b774e000-b774f000 ---p 00153000 08:02 788240 /lib/tls/i686/cmov/libc-2.11.1.so b774f000-b7751000 r-xp 00153000 08:02 788240 /lib/tls/i686/cmov/libc-2.11.1.so b7751000-b7752000 rwxp 00155000 08:02 788240 /lib/tls/i686/cmov/libc-2.11.1.so b7752000-b7755000 rwxp 00000000 00:00 0 b7755000-b7757000 r-xp 00000000 08:02 788243 /lib/tls/i686/cmov/libdl-2.11.1.so b7757000-b7758000 r-xp 00001000 08:02 788243 /lib/tls/i686/cmov/libdl-2.11.1.so b7758000-b7759000 rwxp 00002000 08:02 788243 /lib/tls/i686/cmov/libdl-2.11.1.so b7759000-b7760000 r-xp 00000000 08:02 794660 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/jli/libjli.so b7760000-b7762000 rwxp 00006000 08:02 794660 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/jli/libjli.so b7762000-b7777000 r-xp 00000000 08:02 788254 /lib/tls/i686/cmov/libpthread-2.11.1.so b7777000-b7778000 r-xp 00014000 08:02 788254 /lib/tls/i686/cmov/libpthread-2.11.1.so b7778000-b7779000 rwxp 00015000 08:02 788254 /lib/tls/i686/cmov/libpthread-2.11.1.so b7779000-b777b000 rwxp 00000000 00:00 0 b777b000-b777c000 r-xs 00000000 08:02 137421 /var/cache/fontconfig/4794a0821666d79190d59a36cb4f44b5-le32d4.cache-3 b777c000-b777e000 r-xs 0000b000 08:02 795451 /opt/SweetHome3D-2.3/lib/Loader3DS1_2u.jar b777e000-b7780000 r-xs 00076000 08:02 795453 /opt/SweetHome3D-2.3/lib/Textures.jar b7780000-b7781000 rwxp 00000000 00:00 0 b7781000-b7782000 r-xp 00000000 00:00 0 b7782000-b778d000 r-xp 00000000 08:02 794708 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/libverify.so b778d000-b778e000 rwxp 0000b000 08:02 794708 /opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/libverify.so b778e000-b7790000 rwxp 00000000 00:00 0 b7790000-b7791000 r-xp 00000000 00:00 0 [vdso] b7791000-b77ac000 r-xp 00000000 08:02 787981 /lib/ld-2.11.1.so b77ac000-b77ad000 r-xp 0001a000 08:02 787981 /lib/ld-2.11.1.so b77ad000-b77ae000 rwxp 0001b000 08:02 787981 /lib/ld-2.11.1.so bfdca000-bfddf000 rwxp 00000000 00:00 0 [stack] VM Arguments: jvm_args: -Djava.library.path=./lib -Xmx1024m java_command: com.eteks.sweethome3d.SweetHome3D -open Launcher Type: SUN_STANDARD Environment Variables: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/opt/real/RealPlayer USERNAME=matstardust LD_LIBRARY_PATH=/opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386/client:/opt/SweetHome3D-2.3/jre1.6.0_18/lib/i386:/opt/SweetHome3D-2.3/jre1.6.0_18/../lib/i386 SHELL=/bin/bash DISPLAY=:0.0 Signal Handlers: SIGSEGV: [libjvm.so+0x417270], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGBUS: [libjvm.so+0x417270], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGFPE: [libjvm.so+0x33ccc0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGPIPE: [libjvm.so+0x33ccc0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGXFSZ: [libjvm.so+0x33ccc0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGILL: [libjvm.so+0x33ccc0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000 SIGUSR2: [libjvm.so+0x33f900], sa_mask[0]=0x00000000, sa_flags=0x10000004 SIGHUP: [libjvm.so+0x33f630], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGINT: [libjvm.so+0x33f630], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGTERM: [libjvm.so+0x33f630], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGQUIT: [libjvm.so+0x33f630], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 --------------- S Y S T E M --------------- OS:squeeze/sid uname:Linux 2.6.32-21-generic #32-Ubuntu SMP Fri Apr 16 08:10:02 UTC 2010 i686 libc:glibc 2.11.1 NPTL 2.11.1 rlimit: STACK 8192k, CORE 0k, NPROC infinity, NOFILE 1024, AS infinity load average:0.89 1.06 1.00 CPU:total 1 (1 cores per cpu, 1 threads per core) family 6 model 10 stepping 0, cmov, cx8, fxsr, mmx, sse, mmxext, 3dnow, 3dnowext Memory: 4k page, physical 1026344k(34260k free), swap 2104472k(2103732k free) vm_info: Java HotSpot(TM) Client VM (16.0-b13) for linux-x86 JRE (1.6.0_18-b07), built on Dec 17 2009 13:58:25 by "java_re" with gcc 3.2.1-7a (J2SE release) time: Sat May 1 10:59:33 2010 elapsed time: 1 seconds
[May 1, 2010, 12:03:33 PM]
[Link]
Re: ubuntu lucid problem
Stardust: On my PC I also use Ubuntu 10.04 Lucid and SH3D v2.3. It's the most recent installer version which you can download here . Clicking Help --> About in SH3D shows that I'm using Java 1.6.0_18. On my PC it works flawlessly. As I'm 100% non-technical I can't help you with your log files. Maybe Emmanuel can distill some higher truth from it. In case it's of any use, I attach a screen shot of Synaptic Package Manager that shows which Java-related programs I have installed. Hans
Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB
[May 1, 2010, 3:28:41 PM]
[Link]
Crashes generally happen because of problems with video drivers. Stardust, please check it.
[May 1, 2010, 4:37:42 PM]
[Link]
