Advanced Staircase generator plug-in v4.0
The Staircase Generator is a plug-in designed for Sweet Home 3D that allows users to create highly customizable 3D staircases. The tool features a comprehensive parameters menu for fine-tuning dimensions, structural elements, handrails, and midrails. It also includes an integrated 2D Shape Designer for creating custom handrail profiles.
Real-World Application: Whether you are an interior designer pitching a sleek, modern glass-railing loft, or an architect ensuring a multi-story traditional home meets building codes, this plug-in provides the exact geometrical control you need.
Romania
Re: Advanced Staircase generator plug-in v4.0
I tested it, it works, and it's a very laborious plugin. Congratulations! Some of the new features don't work (yet), but I think you'll get them to work (Y-shaped or T-shaped stairs). The profile editor is very interesting (at least for me). May I use it as inspiration for my other plugins? In return, I could try to organize your source code better. 7625 lines in a single sheet is a bit too much and difficult to manage.
Translated with DeepL.com (free version)
@dorin The translation is much, much better now! No 'funny' language constructions from a bad translator
Romania
@Keet
Is the same translator used in the past. The 'funny' constructions is 'my signature', it is part of mine. BTW My son has told me the same
Gents, feel free to update/upgrade/improve the plugin as you see fit
The Y shaped T shaped Inverted T Y shaped are a bit beyond my expertise so give it a try.
---------------------------------------- Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins
And yes you can use the shape designer code or upgrade it :-)
Round landings or Polygonal landings also need to be added ;-)
Romania
Hi! I tried to organize the source files a little better. Here is the plugin and here is the Eclipse folder. Thanks for accepting!
@dorin NICE WORK :-) Now try Adding Round landings, Elliptical landings and Polygonal landings Adding Y shaped, T shaped, Inverted Y shaped, Inverted T shaped Cheers
