Total posts in this thread: 4
Previous Thread This topic has been viewed 9019 times and has 3 replies Next Thread
yafeng
same texture appears different after imported as OBJ
Hello,
I'm desiging a two-levelled house with sh3d by importing second layer as OBJ on top of the first layer.
But one annoying issue is, wall texture imported in OBJ file look differnt in 3D view, meaning even you align first-floor wall perfectly to another piece of imported second-floor wall, they don't appear as one piece. This happens when you apply a texture to the walls, not an issue if you apply color to the walls.
Any idea how to solve this problem?
BTW, after rendering, wall texture will look same, but it's still quite annoying since it's the 3D view that you work on most time.
P.S.
I prepared one example picture, but seems this board doesn't support uploading images directly.
[Apr 14, 2010, 9:21:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: same texture appears different after imported as OBJ
Yafeng:
You can use www.mediafire.com or a similar service to upload your file and/or picture and give us a link to it.
[Apr 15, 2010, 12:21:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Yafeng, I see what you mean. Textures applied to walls, floors, ceilings, ground and furniture aren't managed the same way as the ones read from OBJ files.
Please, fill a bug report. I'll try to fix it.
Attachment Textures.sh3d (42939 bytes) (Download count: 608529) (Textures looking different)
[Apr 15, 2010, 10:03:34 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
yafeng
Good, thanks for the information. A bug is reported about this.
[Apr 15, 2010, 8:04:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
