SH3D kinda makes a no-crash
Emmanuel:
Under Ubuntu 10.04 SH3D v2.3 (the jnlp-version) behaves a bit strange these last days (weeks). When I open the program and draw a wall, everything is fine. I can insert a door or window, I can insert furniture.
But when I am not active for a few minutes, "half" of the program freezes. I still can draw walls and rotate the 3D view, but it's impossible to insert any further furniture.
Maybe there is a solution?
Re: SH3D kinda makes a no-crash
Would you have a stack trace in the Java console window? To display the Java console window: - run "javaws -viewer" command which opens two windows, - close Java cache viewer window, - click on the Advanced tab in the Java control panel window, - select Show console in Parameters > Java console, - click on OK, - relaunch Sweet Home 3D.
I guess you don't use Sun JVM. What is the answer to the command "java -version"?
Emmanuel:
In the picture above you can see the terminal window with the command I typed.
The second window is the ONLY response I get.
As far as I can see, I have some "compatible" Java version installed. I looked on the Sun website, but it's rather complicated to install Jave from their site. I'm so clumsy that I would prefer not to follow that list of instructions, as I'm afraid of screwing things up.
