Previous Thread This topic has been viewed 8890 times and has 12 replies Next Thread
SW3DFnx
Launch failure: sunflow-0.07.3b.jar
Bonjour,
Since end of march 2010, I managed to run SH3D-2.3 once.
I have used SH3D from time to time before without problem.
Since then, I get a failure message after the launch starting with with the following error:
Any advice to correct this problem ?
OS: linux Ubuntu 8.04.4 LTS (Hardy)
[Apr 4, 2010, 9:49:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Launch failure: sunflow-0.07.3b.jar
Sorry, I didn't understand whether Sweet Home 3D runs or not on your computer, once the message you mention appears.
For your information, sunflow-0.07.3b.jar library doesn't exist anymore and was replaced by sunflow-0.07.3c.jar in Sweet Home 3D 2.3.
[Apr 5, 2010, 9:52:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SW3DFnx
SH3D-2.2 was starting and ran on my computer
Now, the program is starting, but is not running anymore: I get the welcome display (SweetHome 3D, eteks), and then two windows:
  • "Java Web Start" and
  • "Erreur d'application: impossible de lancer l'application"
    FYI, I'm lauching the application with the following command:
    /usr/bin/javaws $HOME/SweetHome3D/SweetHome3D.jnlp
  • [Apr 5, 2010, 11:35:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
    Why don't you just double-click the program icon?
    [Apr 6, 2010, 1:05:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
    SW3DFnx
    To hansmex: The double click calls the same command and causes the exact same behaviour.
    I have also tried to reinstall SH3D by clicking on the banner "Lauch SH3D with Java Web Start" on page http://www.sweethome3d.eu/download.jsp but it only brings me the Java official download page.
    By the way, the version of javaws installed on my computer is "Java(TM) Web Start 1.6.0_17"
    [Apr 6, 2010, 2:01:29 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
    SW3DFnx:
    Why don't you try an upgrade to Lucid 10.04? It's still a beta, but very stable. When using Ubuntu 8.04 I had problems with outdated video drivers, that were solved after upgrading to 09.10. However, 9.10 wasn't very stable, so I decided to upgrade to 10.04 which you can find here .
    SH3D works fine on my computer.
    [Apr 6, 2010, 4:02:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
    Please, click on the Details button, and copy paste here the information shown in the Exception tab (onglet).
    [Apr 7, 2010, 3:26:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
    SW3DFnx
    Here is the content of "Exception" tab:
    java.io.FileNotFoundException: http://www.sweethome3d.eu/lib/sunflow-0.07.3b.jar
    at sun.reflect.GeneratedConstructorAccessor2.newInstance(Unknown Source)
    at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
    at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
    at sun.net.www.protocol.http.HttpURLConnection$6.run(HttpURLConnection.java:1368)
    at java.security.AccessController.doPrivileged(Native Method)
    at sun.net.www.protocol.http.HttpURLConnection.getChainedException(HttpURLConnection.java:1362)
    at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1016)
    at com.sun.deploy.net.BasicHttpRequest.doRequest(BasicHttpRequest.java:225)
    at com.sun.deploy.net.BasicHttpRequest.doGetRequestEX(BasicHttpRequest.java:68)
    at com.sun.deploy.net.DownloadEngine.isUpdateAvailable(DownloadEngine.java:910)
    at com.sun.deploy.net.DownloadEngine.isUpdateAvailable(DownloadEngine.java:816)
    at com.sun.deploy.net.DownloadEngine.getResourceCacheEntry(DownloadEngine.java:1536)
    at com.sun.deploy.net.DownloadEngine.getResourceCacheEntry(DownloadEngine.java:1496)
    at com.sun.deploy.net.DownloadEngine.getResource(DownloadEngine.java:217)
    at com.sun.javaws.LaunchDownload.downloadJarFiles(LaunchDownload.java:920)
    at com.sun.javaws.LaunchDownload.downloadEagerorAll(LaunchDownload.java:803)
    at com.sun.javaws.Launcher.downloadResources(Launcher.java:1310)
    at com.sun.javaws.Launcher.prepareLaunchFile(Launcher.java:838)
    at com.sun.javaws.Launcher.prepareToLaunch(Launcher.java:306)
    at com.sun.javaws.Launcher.prepareToLaunch(Launcher.java:183)
    at com.sun.javaws.Launcher.launch(Launcher.java:104)
    at com.sun.javaws.Main.launchApp(Main.java:403)
    at com.sun.javaws.Main.continueInSecureThread(Main.java:250)
    at com.sun.javaws.Main$1.run(Main.java:111)
    at java.lang.Thread.run(Thread.java:619)
    Caused by: java.io.FileNotFoundException: http://www.sweethome3d.eu/lib/sunflow-0.07.3b.jar
    at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1311)
    at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:373)
    at com.sun.deploy.net.BasicHttpRequest.doRequest(BasicHttpRequest.java:190)
    ... 17 more
    [Apr 7, 2010, 11:42:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
    Referencing a local file to run javaws doesn't seem to be a good choice, when the remote file changed.
    You should run Sweet Home 3D with the command:
    or replace $HOME/SweetHome3D/SweetHome3D.jnlp by its new version available at http://www.sweethome3d.eu/SweetHome3D.jnlp.
    [Apr 8, 2010, 9:20:12 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
    SW3DFnx
    Merci ! the command:
    works very well.
    Is this a relaible method that can be recommended for all linux users when the link "Lauch SH3D with Java Web Start" on page http://www.sweethome3d.eu/download.jsp doesn't work ?
    For Online usage:
    For Offline usage: In a chosen directory, download firstly the SH3D launch file with (for instance):
    And launch SH3D with the command
    /usr/bin/javaws ./SweetHome3D.jnlp
    [Apr 9, 2010, 4:24:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
