Total posts in this thread: 5
Previous Thread This topic has been viewed 149 times and has 4 replies
webrehm
Can't create a pdf
I used this program off and on for several years and have never been able to create a pdf. When I try I just get a progress window that never makes a functional file. It does create a pdf file but it is empty and the progress window never finishes.
I am on version 7.0.2
What is going on?
tks
Dennis
[May 24, 2025, 8:03:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MarioSambol
Croatia
Re: Can't create a pdf
Try a newer version of the program.
[May 29, 2025, 2:45:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
webrehm
I upgraded to 7.5, still won't create a pdf?? Same exact behavior
[May 29, 2025, 5:27:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Creating a PDF is the same as printing to PDF. Instead of using the menu function Print to PDF you can install a PDF printer driver and print to that "printer" with the Print function. There are many (free) PDF printers you can download so if one doesn't work as you like you can simply uninstall it and try another one.
[Edit 1 times, last edit by Keet at May 29, 2025, 5:46:36 PM]
[May 29, 2025, 5:33:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
webrehm
Tried using the microsoft print to pdf on Win 11 but that did not work. Will try a third party version
[May 29, 2025, 10:11:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
