iaw4
usa
Re: Columns, Beams, and Roofs
Sorry, I wasn't clear. I had already found the solution. What I had not seen was the selector at the top of the right pane that switched between levels. I posted it for others reading the thread.
I also now understand what the roof generator does --- it creates both a new level and a roof sitting on it. I was quite perplexed for a while changing the elevation of my roof, because the level appeared like an unmoving base of the roof. (The roof unfortunately has a minimum height of 1", so one cannot make it flat.)
> In the roof generator you can make sides invisible, set an angle, etc to create a roof. Since your roof is a simple slab of metal you can also use a resized box with a metal texture. Tilt it a little to get the angle you need.
This wasn't the case for me. When I selected the plugin, it only allowed me to set the height, and even that didn't transfer upon insertion.
For my needs, it may well be simpler to just take the plain furniture box from "miscellaneous", change its dimensions, and lift it to look like a roof. That also makes it easy to angle it.
thanks for all the help, K.
[Apr 17, 2025, 9:23:08 PM]
[Link]
