3d view and video
Hello to all. excuse me for my approximate English, but is fruit of a translation from babelfish, as they are Italian and I do not know the language well. I have installed sweet home 3d 2.3. I have realized rows much heavy one (approximately 20 mb) and when I try to make a video or a photo 3d, also to lowland quality, it says to me that not enough memory. I do not have a powerful PC and the graphical card is integrated. Are there a solution for this problem or not? I have tried to power off some members, but practically it works alone with the walls and without furnishings. thanks thousands.
Re: 3d view and video
Sgabu:
SH3D uses a LOT of memory to make a photo or video. This will cause problems, if you don't have much memory,
My suggestion: make a small model (preferably only 1-2 Mb) and try to make a photo in quality setting 1. Don't use textures, because they use a lot of memory.
If you can make a photo in this way, then you know that your computer is working correctly.
ITALIAN TRANSLATION (using Google Translate)
SH3D utilizza una grande quantità di memoria a fare una foto o un video. Ciò causerà problemi, se non si ha molta memoria,
La mia proposta: creare un modello di piccole dimensioni (preferibilmente solo 1-2 Mb) e provare a fare una foto in qualità impostazione 1. Non utilizzare texture, perché usano un sacco di memoria.
Se riesci a fare una foto in questo modo, allora sapete che il vostro computer funziona correttamente.
