Previous Thread This topic has been viewed 1303 times and has 10 replies Next Thread
peng1
The order of my Levels seems to be locked - Why?
I am working with a model that has several (11) 'levels'. for some reason I am no longer able to adjust the order of these levels using the up/down arrows in the 'Modify Level' dialog. A few days ago I was able to move a level from top to bottom but now all levels seem to be stuck.
I can still adjust the order of levels in my old files and also with a new file but this particular file seems locked. File size is ~20MB.
Note that all my levels are at the same elevation, height and floor thickness. I am therefore using levels as 'layers' rather than traditional levels.
Any ideas?
My next step is to start again with a new file and copy each layer into that but I'm interested to know what has gone wrong with this file.
[Mar 16, 2025, 4:22:59 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: The order of my Levels seems to be locked - Why?
In version 7.5 I created 13 (empty) levels and was able to move the selected level up and down.
Check your version and update if necessary, then try to make 11+ empty levels before copying everything to a new file.
[Mar 16, 2025, 6:49:29 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
JonnyD
After over a decade of using SH3D I had no idea you could do this! 😂
[Mar 16, 2025, 7:05:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Little secret.... me neither (after 15+ years)
[Mar 16, 2025, 8:33:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
JonnyD
Us old dogs eh? 😂
[Mar 16, 2025, 9:22:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It's only been available for a "short" time... almost 10 years or so smile
[Mar 16, 2025, 11:26:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
JonnyD
Just goes to show you find new things all the time.
[Mar 16, 2025, 12:13:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Like other colleagues here, I have tried to reproduce your problem (16 levels at same elevation). No success!.
The problem is serious and deserve attention.
My suggestions:
1. Save the file as a different one name (as a backup) and try again.
Sound illogical but it is a test.
2. Inform us about SH3D version and OS.
3. If you trust us share the file here to study it.
Some of us will find the problem.
[Mar 16, 2025, 12:27:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MarioSambol
Croatia
Status: Online
I have been using multiple levels for a long time as layers of the same height and elevation. Usually a maximum of 5 layers, usually first for plan, second furniture, third for light ambient, fourth for light. That way I can easily hide or reveal levels and select objects in the scene. I have had no problems because the order doesn't matter to me, the only thing that matters to me is the hide or show option.
[Mar 17, 2025, 9:35:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
peng1
Thanks all for your inputs. Sorry for slow reply but I got busy.
I am using V7.5 on windows 11 64bit. 16G of RAM.
I spent some time tonight and created a new file and copied all my level contents from the 'stuck' file to this new file. The new file seems to be behaving correctly, ie I can freely manipulate the levels up and down.
So it is looking like my original file is somehow corrupted and for now I am back up and running.
If I find some time I may dig a bit deeper into that old file, deleting layers etc to see if it comes right.
I am reminded that I have recently (months?) started getting SH3D crashes with symptom of CPU/fan ramping up but the UI stops responding and I have to kill the process. Thankfully SH3D does provide file recovery however I wondeer if one of those crashes has corrupted the file? (or vice-versa).
Note that I am using the levels feature for more than just as 'layers', in addition I am using levels to create 'versions' of a design. So I create a level and copy-paste the previous level contents and then edit the new 'level' [version] from there. Some of the plan levels can be quite busy but I do delete old/uneeded levels to avoid file size getting to out of hand. But probably I am just stretching my SH3D/PC system beyond it's limit.
Note also that the reason I might want to change the order of levels is because of strange (and annoying) artifacts* that I see in the plan view that happen with doors when they are positioned close to another wall in a level of lower order, even when that 'lower' level is tagged as not viewable.. Snapping is also affected in a simlarly way.
(*I would add an screenshot of the artifact if I knew how to add images in this editor!).
[Mar 19, 2025, 10:59:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
