michaelbr
Spain
Re: copy/paste between files
You can't copy/paste multiple levels. You have to do this for each level separately. The easiest way is to make only one level visible before you select all on that level and copy it. Paste it on a level in the second project (make sure the elevation, height, and floor thickness are the same). Then repeat for the other levels. OK, it's still not clear for me, on level1 of project1, I have everything, including the wall, on level 2 I have only roof, when I copied the project1, the level1 was visible, so theoretically the wall should be copied. What I'm missing?
Thanks for your comment/suggestion Michael
[Feb 26, 2025, 7:05:31 AM]
[Link]
