Re: Export Plan Image v1.1
Here is a little gadget. A very small Metric<>Imperial Calculator in html/css/javascript. You can run it local without internet connection. With html/css/javascript you have all the source code which allows you to change it every way you like. Metric<>Imperial Calculator
When you have set Imperial as your Sweet Home 3D preference and you import a model or add it from the catalog: make sure you have magnetism off. After import you can switch magnetism on again. If you import with magnetism on then Sweet Home 3D does an automatic conversion to imperial which changes the original dimensions of the model. (obj files contain metric numbers.) This can cause problems with aligning multiple models from a series. This happened with a member that works with imperial and encountered strange alignment problems with my kitchen models. Dragging the models from the catalog with magnetism off solved the problem.
Dodecagon.nl 1300+ 3D models, manuals, and projects
[Mar 2, 2025, 9:50:14 PM]
[Link]
