Total posts in this thread: 6
Previous Thread This topic has been viewed 1069 times and has 5 replies Next Thread
Bereldhuin
Imported object preview on plan is broken
Everytime I'm importing an object, the preview in the plan is always broken.
However, the model is correctly imported and is working fine in the 3D view.
Here is an example of a vacuum:
Preview while importing (OK) :
Preview in the plan (broken):
3D Visualization (OK):
I'm using SH3D 7.5 on Ubuntu 24.04.
Do you have any idea on how to solve this ?
Thanks for your help,
Fred
[Feb 15, 2025, 5:22:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Imported object preview on plan is broken
Sometimes downloaded models have problems that can be solved by export/import.
Try exporting the model and then import it again.
Export: Menu > 3D view > Export to OBJ format,
Import: Menu > Furniture > Import furniture
[Feb 17, 2025, 10:26:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
What Java version do you use (see About dialogbox)?
[Feb 17, 2025, 11:51:42 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bereldhuin
Thanks for your answers.
It seems the problem happens only on Ubuntu. I tested with Windows (the installer version from Sourceforge, not the one provided through the App store) and it works fine.
Under Ubuntu, I'm using the tgz install, with the included runtime which is 1.8.0_202 (Java3D is 1.6.2a - JOGL 2.5.0)
[Feb 17, 2025, 12:49:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bereldhuin
Looking in the preferences, I changed the "Furniture icons in plan" to "Top view" and objects are now displayed correctly.
However, it's still not the case in the left panel.
[Feb 17, 2025, 12:53:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If you start with the script SweetHome3D try the other script: SweetHome3D-Java3D-1_5_2, works perfectly for Linux
[Feb 17, 2025, 1:03:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
