Previous Thread This topic has been viewed 1170 times and has 10 replies Next Thread
skank
Pond
Hi
I have created my garden
I created a second floor beneath it.
Made some walls of the pond
When i look back to my floor plan, i can see the walls going down. Which is great
What i want to do now, is to have it filled with water :p but keep the transparancy
How can i do that?
Cause when i add floor at +0, transparancy and walls are gone..
I cant leave it blank either, curious
[Jan 22, 2025, 6:25:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MarioSambol
Croatia
Re: Pond
I think you should have an object with transparency on it and some kind of water surface texture.
[Jan 22, 2025, 8:02:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
skank
Re: Pond
How do i give an object transparancy?
[Jan 24, 2025, 4:55:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
JonnyD
Re: Pond
Find a glass shelf and alter the materials so only the glass is visible. Change the glass texture to water and stretch it to fit your pond. You may need to use it in your negative layer
[Jan 24, 2025, 5:20:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Pond
The tips&tricks page seems to have disappeared. There was a sample project there that had step-by-step descriptions on how to create a pond/swimmingpool.
It's not that difficult. You already have the hole but you are missing the water.
Stretch a shallow box so it completely covers the opening of the hole. Make all sides except the top invisible and set the water texture from the texture list for the top. Export the object. Edit the mtl file and add a line "d 0.4" at the bottom of the "newmtl top" block.
Save and import. Put the object on the below ground level and elevate it to where you want the top of the water to be. Done.
Setting a value for d closer to 1.0 makes the water less transparent if that is what you need.
[Jan 24, 2025, 6:06:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
skank
Re: Pond
@KEet its chinese for me, how do i do a shallow box
Willing to give me such an object? it can be a rectangle
[Jan 24, 2025, 6:22:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Pond
You can drag a box from the catalog and resize it. Just set it's height to 1 cm or so, doesn't really matter since the actual height will disappear anyway.
When you modify the box you can click the button "Materials" on the bottom left of the dialog. It then shows 6 sides for materials: top, bottom, left, right, front, and back. You can make them invisible in the same dialog suing the radio button "invisible". Only the top should remain: click the button "Texture" and from the texture list select a water texture (type 'water' in the little box at the bottom of the list). Click OK, OK and you can export the box.
Set the d value in the MTL file that results from the export. Import the OBJ file and you have your water.
[Jan 24, 2025, 6:32:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
skank
Re: Pond
i can only export to svg or csv not obj
[Jan 24, 2025, 6:39:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
skank
Re: Pond
got it
[Jan 24, 2025, 6:40:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
skank
Re: Pond
this is the mtl now
# Generated by Sweet Home 3D - vr jan 24 19:40:11 CET 2025
# http://www.sweethome3d.com/
newmtl top
illum 2
Ka 0.2 0.2 0.2
Kd 1.0 1.0 1.0
Ks 0.46875 0.46875 0.46875
Ns 60.0
d 0.4
[Jan 24, 2025, 6:42:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
