Previous Thread This topic has been viewed 2648 times and has 2 replies Next Thread
Bug? No lightSourceMaterialName when Door or window
I ran into an unexpected problem with a window where I wanted to assign the lightSourceMaterialName property to a part of a window. The problem is simple: you can't set the property in the Furniture Library Editor when the object is a Door or window.
I tried to cheat by manually adding the lightSourceMaterialName property in the library properties file but of course that didn't work.
I can't think of any logical reason why this shouldn't work for a window. For a staircase it does work. I tried it, the library property is available and there's a power property when you modify the staircase. A lighted side panel looks good in a render!
Is there a reason why this doesn't work for a window or is this a bug?
950+ 3D models, manuals, and projects
[Nov 18, 2024, 12:19:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Bug? No lightSourceMaterialName when Door or window
Sorry, it’s probably a misconception from me. HomeLight and HomeDoorOrWindow classes are subclasses of HomePieceOfFurniture with no link between them, whereas light should have probably been a property of HomePieceOfFurniture.
[Nov 18, 2024, 12:54:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If I read that right there's no chance of a fix without breaking backward compatibility?
[Edit 1 times, last edit by Keet at Nov 19, 2024, 8:24:56 AM]
[Nov 18, 2024, 1:00:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
