South Africa
Visibility
I have been looking, but can't find if this is somehow already possible
I want to highlight many items in the furniture list, and then do one click to tick or untick their visibility boxes, instead of having to go to each one to tick or untick its visible box
Is there such a feature or not available.
I did highlighted a lot of items, and then hoped there would be an option on the right click menu for "Tick/Untick", but sadly don't see such an option
Re: Visibility
This can not be done by default. But there is trick you can use. Highlight the items and group them. Then tick the invisible box to what you want. Ungroup and all items that were in the group will keep the selected tick.
If you select a mix of visible and invisible items grouping will make them all visible but you can untick the visible box for the group if you want them to be invisible and then ungroup.
---------------------------------------- Dodecagon.nl 1000+ 3D models, manuals, and projects
