Re: Pool house
its a bit a pitty that pool level and ground level look so equal. (maybe its a limitation of the program to not offer negative elevations . but i am not deep enough into it right now.)
Re: Pool house
I would like to make a pool in my Sweethome3D that seems like an actual pool. Do you know when (if they do) Sweethome3D will create a Swimming Pool as furniture? If not, do you know anywhere that i can import a 3D swimming pool to my home?
~Kayla~
Re: Pool house
Thanks... And sorry I asked more than once, I saw that you weren't online and I was hoping somebody else might have answered.
~Kayla~
Re: Pool house
macfrog,
Please, check the date that picture was posted... It's from way before I figured out all the tricks I've written about since. So you see, I have (had) the same learning curve as everybody.
Example? The design was made shortly after or before textures could be applied to boxes. So I made a box with a wooden texture and then repeated it 200 times to form the wooden "envelope" that forms floor, wall and ceiling.
I hadn't thought of stacking "layers" yet in those days, that's why the pool is at the same level as the rest.
[Edit 1 times,
last edit by hansmex at Aug 19, 2011, 11:30:02 PM]
