Hello - I have installed the latest version of Sweet Home (2.2). In the beginning, things looked OK and I was able to define a room and save it. But whe I open this file I get an error message (wording may not be literal as I translated it from German) " Sweet Home 3D is terminated because of a severe rendering error. Please update the drivers of the graphic card." I am running Sweet Home on an E8310 Lifebook, which to my knowledge does not have a graphic card. In addition, the same error message is generated independent of using the built-in laptop display or an external monitor. What can I do? Thanks Heinz J
Re: 3D Driver problem
Even netbooks have at least some kind of integrated graphic card and/or drivers for it, otherwise there wouldn't be anything on screen! On what system are you trying Sweet Home 3D? If you're on Windows, did you try the solutions described in the FAQ?
