Total posts in this thread: 15
Posts: 15   Pages: 2   [ 1 2 | Next Page ]
Previous Thread This topic has been viewed 2875 times and has 14 replies Next Thread
lubimaer
Canada
Video render works first time only
Hi Folks,
I'm pretty new to this forum so please bare with me if this is not the proper way to report this behaviour
I have installed SH3D v7.2
OpenJDK v 11.1.18 - 64bit - 2GB
Java3D v1.6.2a
VideoRendering v2.4.1
Everything seems to work fine so far
The only exception is the video rendering that only works the first time after loading the app
Any further tentative to click on the "create" button in the "video rendering" window generates no results
No crash, just no action
I couldn't find anything similar in this forum or in the bugs repository
Any idea what should I try?
Thanks,
Marco
[Mar 11, 2024, 8:42:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Video render works first time only
Did you install the 64 bit or the 32 bit version of SH3D?
[Mar 12, 2024, 1:33:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
lubimaer
Canada
Good question
Downloading for windows automatically redirected me to an installer that I assumed it was 64bit
But if I run SysInternal command from Microsoft it looks like the app is 32bit
Here's SysInternal output
C:\Program Files\Sweet Home 3D>\Users\cqvw46\Desktop\download2\sigcheck.exe SweetHome3D.exe
Sigcheck v2.90 - File version and signature viewer
Copyright (C) 2004-2022 Mark Russinovich
Sysinternals - www.sysinternals.com
C:\Program Files\Sweet Home 3D\SweetHome3D.exe:
Verified: Signed
Signing date: 5:35 AM 9/22/2023
Publisher: PUYBARET EMMANUEL
Company: eTeks
Description: Sweet Home 3D
Product: Sweet Home 3D
Prod version: 7.2
File version: 7.2
MachineType: 32-bit
BUT
Task Manager is telling me I'm running SH3D using:
Zulu Platform x64 Architecture
So the answer is: My machine is 64bit but I'm not sure what I'm running
Marco
[Mar 12, 2024, 5:04:14 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
When installing, there's a screen that asks whether you want the 64 or 32 bit version. Please, reinstall and check...
[Mar 12, 2024, 5:41:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
lubimaer
Canada
Hi Hans,
Thanks for the feedback
I have uninstalled SH3D and reinstalled selecting 64bit:
Nothing changed.
Is it possible to check logs for any error message?
Thanks
Marco
[Mar 12, 2024, 9:44:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
How large is your SH3D file?
Can you check in About dialog how much memory is used by the Sweet Home 3D before and after you render a video (the numbers cited after "64 bit")?
[Mar 12, 2024, 10:01:18 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
lubimaer
Canada
Before = 0.1/2.8G
After = 0.1/2.8G
It happens with any file
I've also created a very simple scene with just a chair
Video works the first time but stops working after that
Workaround is to close SH3D and restart
Marco
[Mar 12, 2024, 5:36:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for the information. This doesn’t look like a memory shortage issue.
Please run Sweet Home 3D from the command line with a command like:
"C:\Program files\Sweet Home 3D\SweetHome3D.exe" 2>log.txt
and post here what the text of log.txt when you try to render a video a second time.
[Mar 12, 2024, 5:47:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
lubimaer
Canada
Hi Emmanuel,
Please find here the trace when starting the app
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by javax.media.j3d.JoglPipeline (file:/C:/Program%20Files/Sweet%20Home%203D/lib/java3d-1.6/j3dcore.jar) to method sun.awt.AppContext.getAppContext()
WARNING: Please consider reporting this to the maintainers of javax.media.j3d.JoglPipeline
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
Running a second time the video rendering adds the following
Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: Comparison method violates its general contract!
at java.base/java.util.ComparableTimSort.mergeHi(ComparableTimSort.java:870)
at java.base/java.util.ComparableTimSort.mergeAt(ComparableTimSort.java:487)
at java.base/java.util.ComparableTimSort.mergeCollapse(ComparableTimSort.java:413)
at java.base/java.util.ComparableTimSort.sort(ComparableTimSort.java:213)
at java.base/java.util.Arrays.sort(Arrays.java:1249)
at java.desktop/sun.awt.shell.Win32ShellFolderManager2.get(Win32ShellFolderManager2.java:313)
at java.desktop/sun.awt.shell.ShellFolder.get(ShellFolder.java:259)
at java.desktop/com.sun.java.swing.plaf.windows.WindowsFileChooserUI$DirectoryComboBoxModel.addItem(WindowsFileChooserUI.java:1087)
at java.desktop/com.sun.java.swing.plaf.windows.WindowsFileChooserUI.doDirectoryChanged(WindowsFileChooserUI.java:74
1)
at java.desktop/com.sun.java.swing.plaf.windows.WindowsFileChooserUI$11.propertyChange(WindowsFileChooserUI.java:832)
at java.desktop/java.beans.PropertyChangeSupport.fire(PropertyChangeSupport.java:341)
at java.desktop/java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:333)
at java.desktop/java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:266)
at java.desktop/java.awt.Component.firePropertyChange(Component.java:8731)
at java.desktop/javax.swing.JFileChooser.setCurrentDirectory(JFileChooser.java:608)
at java.desktop/javax.swing.JFileChooser.<init>(JFileChooser.java:362)
at java.desktop/javax.swing.JFileChooser.<init>(JFileChooser.java:308)
at com.eteks.sweethome3d.swing.FileContentManager$DirectoryChooser.<init>(Unknown Source)
at com.eteks.sweethome3d.swing.FileContentManager.showFileChooser(Unknown Source)
at com.eteks.sweethome3d.swing.FileContentManager.showSaveDialog(Unknown Source)
at sh3dPlugin.AdvancedVideoPanel.startVideoCreation(AdvancedVideoPanel.java:1851)
at sh3dPlugin.AdvancedVideoPanel.access$11(AdvancedVideoPanel.java:1844)
at sh3dPlugin.AdvancedVideoPanel$10.actionPerformed(AdvancedVideoPanel.java:367)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1967)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2308)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:405)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:262)
at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:279)
at java.desktop/java.awt.Component.processMouseEvent(Component.java:6635)
at java.desktop/javax.swing.JComponent.processMouseEvent(JComponent.java:3342)
at java.desktop/java.awt.Component.processEvent(Component.java:6400)
at java.desktop/java.awt.Container.processEvent(Container.java:2263)
at java.desktop/java.awt.Component.dispatchEventImpl(Component.java:5011)
at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2321)
at java.desktop/java.awt.Component.dispatchEvent(Component.java:4843)
at java.desktop/java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4918)
at java.desktop/java.awt.LightweightDispatcher.processMouseEvent(Container.java:4547)
at java.desktop/java.awt.LightweightDispatcher.dispatchEvent(Container.java:4488)
at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2307)
at java.desktop/java.awt.Window.dispatchEventImpl(Window.java:2772)
at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:772)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:721)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:715)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:85)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:95)
at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:745)
at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:743)
at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:742)
at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
[Mar 12, 2024, 7:04:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sjb007
Check the last couple of pages of the 7.2 release thread here in the forums. It looks like you have hit the same error as snmavronis.
Perhaps Emmanuel could send you his 7.3 beta to test too.
[Mar 13, 2024, 1:05:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
