Previous Thread This topic has been viewed 722 times and has 2 replies Next Thread
ArtOfHome
Italy
Padding from objects
Is it possible to create an invisible space between 2 objects? Perhaps a padding of 1 centimeter to always leave an equally spaced gap when they are joined?
[Feb 15, 2024, 11:14:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Padding from objects
Yes: create a box with the needed size. Make all sides invisible except the top. Export it and edit the MTL file so the single block of material "top" gets a last line with "d 0.0". This makes the box invisible.
Import and you can use this object as an invisible space. Only the gap width needs to be precise. The object is invisible anyway so as long as it doesn't stick outside your other objects it's good.
Edit to complete:
While you're editing the MTL file change "newmtl top" to "newmtl invisible" and in the OBJ file change "usemtl top" to "usemtl invisible". When you import the object its material name will be "invisible". This makes it easier to recognize it when you combine it in an export with other objects.
Edit 2 for all users:
The invisible box is useful for something else. Imagine you created several pieces of furniture that can be stacked BUT they don't all have the same size (bounding box). That makes aligning them while you stack them difficult.
By adding invisible boxes to the smaller parts you can make sure that the bounding boxes are all the same size so your parts can be easily aligned.
[Edit 2 times, last edit by Keet at Feb 15, 2024, 11:34:08 AM]
[Feb 15, 2024, 11:23:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
For this kind of tasks I usually use the already old implemented tool "Align or distribute furniture" which have 9 aligning types and 2 distribution (horizontal and vertical).
I've added also an "Distribute elevation plugin" to complete this options.
[Feb 15, 2024, 1:21:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
