Total posts in this thread: 7
Previous Thread This topic has been viewed 1426 times and has 6 replies Next Thread
ArtOfHome
Italy
MAgnetism and alignment side-by-side
When 2 objects are grouped together, magnetism doesn't work, is there a way?
Automatic side-by-side alignment doesn't work on all sides.
[Feb 15, 2024, 9:09:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: MAgnetism and alignment side-by-side
Select them individually in the group by clicking a second time on one of the objects of the group then selecting the second one by clicking on it with shift key pressed. You may also select them in the furniture list.
Side by side alignment aligns the second and following objects of the selection on the back of the first selected object (opposite side of the thicker line of its selection rectangle), without rotating them. So pay attention to which object is first selected.
[Feb 15, 2024, 9:22:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ArtOfHome
Italy
I know how to select multiple grouped objects.... The question was when I select one of the objects in the group, it doesn't magnetically snap to another object in the group. Do I have to separate them first...
[Feb 15, 2024, 11:08:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Do the parts that need to be aligned with magnetism share the same elevation, or at least partial share in height? I found that objects on a different elevation don't align through magnetism.
[Feb 15, 2024, 11:16:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sorry, I didn't read you correctly. You're right, magentism doesn't work for objects within a group and you need to ungroup them first. Maybe I should improve this behavior...
Keet, your comment is right but magnetism doesn't work for two objects at different elevations only if the bottom of the higher object is higher than the top of the lower one. Logical, not?
[Feb 15, 2024, 11:34:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Yep logical, I just though I would point it out since that might have been the cause of the failed magnetism snap. I totally missed the part that the two objects were in a group smile
It would be nice if magnetism would work inside a group, I often rearrange objects in a group.
[Feb 15, 2024, 11:37:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ArtOfHome
Italy
Adding a "align top with bottom," for example, would suffice. Because in the case depicted in the image, if I use the "align side by side," they overlap. Yes, there's magnetism, but sometimes it's difficult. An "align top with bottom" or even "bottom with bottom" would be very useful.
example_image
[Feb 15, 2024, 1:29:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
