Total posts in this thread: 7
Previous Thread This topic has been viewed 1577 times and has 6 replies Next Thread
Vilgard
Door with two different sides
Hello I am looking for an interior door (if possible that can be opened) with 2 sides of different color / texture
[Jan 11, 2024, 5:07:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Door with two different sides
Several options:
• Create your own door
• If you're lucky the door you like exports with separated groups. This would make separating front and back a lot easier. See the How-To listed below.
• If you're not that lucky you need something like Blender to separate the front and back materials.
This thread explains how to add deformations (opening the door)
Here is a How-To to change material names:
https://dodecagon.nl/Docs/ChangeMaterialNames/Change_Material_Names.pdf
https://dodecagon.nl/Docs/ChangeMaterialNames/Change_Material_Names_files.zip
[Jan 11, 2024, 5:37:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The catalog proposes a front door with materials different for its two sides, but you’re right there’s no interior door with similar ability.
I could create one based on an existing model. Which one in the library would you prefer it looks like?
[Jan 11, 2024, 6:34:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Vilgard
Thank you.
If you could create one based on the classic "door" by eTeks it will be perfect
https://www.sweethome3d.com/searchModels.jsp?model=eTeks+door
[Jan 12, 2024, 4:09:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You'll find the door in the library DoorWithTwoSides.sh3f.
Hope it has enough materials to create the arrangement you want to achieve.
[Jan 12, 2024, 6:47:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Oh oh! Thank you Emmanuel, most useful!
[Jan 12, 2024, 9:29:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Vilgard
@ Puybaret
Wahooo ! thank you it is exactly what i was looking for ! applause
I will definitely use it very often.
Everything is perfect, thank you again for your help biggrin
[Jan 13, 2024, 10:19:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
