Total posts in this thread: 2
Previous Thread This topic has been viewed 1041 times and has 1 reply Next Thread
You can use a mathematical formula in numerical input fields
In this thread(French) Emmanuel mentions that it is possible to use a mathematical formula in numerical input fields.
I think it's worth mentioning in a separate topic so a larger group of users gets to know this.
What you can do is enter a formula like "100+3" or "((2*12.5)/3)+22" and the result will be set as the value.
add: +
subtract: -
multiply: *
divide: /
exponent: ^ (2^4 = 2*2*2*2 = 16)
You can use parenthesis to force the order of calculation.
[Edit 1 times, last edit by Keet at Dec 10, 2023, 1:50:48 PM]
[Dec 10, 2023, 1:50:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: You can use a mathematical formula in numerical input fields
Thanks Keet for the recall of this feature which appeared in version 6.0.
As explained in Tips section of the help, you may even use the math functions LN, LOG, EXP, SQR, SQRT, COS, SIN, TAN, ARCCOS, ARCSIN, ARCTAN.
[Dec 10, 2023, 4:07:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
