Previous Thread This topic has been viewed 61184 times and has 90 replies Next Thread
Re: Sweet Home 3D 7.2
Keet, this solution won't fix Steve's problem to save photos. It looks like Sweet Home 3D is just unable to display a file dialog box in Steve's case.
Steve, could you check if there's some error log that could explain your issue?
Please open a cmd window and run Sweet Home 3D redirecting errors to a file with a command like:
"C:\Program Files\Sweet Home 3D\SweetHome3D.exe" 2>Desktop\log.txt
Then choose File > Save as menu item in Sweet Home 3D and quit. If the file log.txt contains something, please post it here.
[Feb 23, 2024, 5:54:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
If we are lucky then there will be some java stacktrace written to stderr. You may apply the following steps to help us identify the problem:
1) Download this plugin and place it under "C:\Users\your_username\eTeks\Sweet Home 3D\plugins".
2) Start SH3D and reproduce the problem, then close SH3D (press cancel if required).
3) Open the file "C:\Users\your_username\eTeks\Sweet Home 3D\log.txt", copy the content and post it here (please use the Code button to format the text).
P.S. for Emmanuel: sorry, we have written at the same time.
[Edit 1 times, last edit by Daniels118 at Feb 23, 2024, 6:02:20 PM]
[Feb 23, 2024, 5:59:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
I just realized the text export I did was not the main software list. It must be dependent sub-programs and other stuff. Here is a list that I just hand typed because you can't copy/paste from the Settings screens:
4K Video Downloader
Abelton Live 11 Lite
AMD Product Verification Tool
AMD Software
Apple Mobile Device Support
Apple Software Update
Arcade Game Series: Galaga
Arcade Game Series: Ms. Pac-Man
ASIO4All
Audacity
Bonjour
Canon IJ Printer Assistant Tool
Canon IJ Scan Utility
Canon TS6400 Series Driver
Corsair iCUE5 Software
CPUID CPU-Z MSI
Dashboard
DesktopOK
Discord
DOOM
Flight Of Nova Demo
Focusrite Audio drivers
GIMP
Google Calendar
Google Chrome
Guitar Pro 8
Intel(R) Chipset Device Software
Intel(R) Wireless Bluetooth(R)
Intel Management Engine Components
iTunes
LibreOffice
MalwareBytes Pro
Microsoft Edge
Microsoft Edge WebView2 Runtime
Microsoft Update Health Tools
Microsoft Visual C++ 2010 x64 Redistributable
Microsoft Visual C++ 2010 x86 Redistributable
Microsoft Visual C++ 2012 Redistributable (x64)
Microsoft Visual C++ 2012 Redistributable (x86)
Microsoft Visual C++ 2013 Redistributable (x64)
Microsoft Visual C++ 2013 Redistributable (x86)
Microsoft Visual C++ 2015-2022 Redistributable (x64)
Microsoft Visual C++ 2015-2022 Redistributable (x86)
MSI Center SDK
Notepad++ (64-bit x64)
OpenShot Video Editor
Pinball Arcade
Quake
Quake Champions
Quake Live
Realtek Audio Driver
Remote Desktop Connection
Standard Soundbank
Steam
Sweet Home 3D
VLC Media Player
[Feb 23, 2024, 10:32:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for this list but it won’t help me to solve your issue (yet).
Please try to get the error logs as explained in my previous post.
[Feb 23, 2024, 10:50:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
I installed the plugin but I can't find the log.txt file that would have been created today. I searched my entire computer.
Just to note the SH3D program on my PC is installed at:
"D:\Program Files (x86)\Sweet Home 3D"
All my saved data (house plans folder) files, renders, plugins etc. are located at these locations:
"C:\Users\snmav\Pictures\House Plans"
"C:\Users\snmav\Pictures\House Plans\Custom"
"C:\Users\snmav\Pictures\House Plans\Models"
"C:\Users\snmav\Pictures\House Plans\OldSH3D"
"C:\Users\snmav\Pictures\House Plans\Plug-ins"
"C:\Users\snmav\Pictures\House Plans\Renders"
"C:\Users\snmav\Pictures\House Plans\SH3D Models"
"C:\Users\snmav\Pictures\House Plans\SH3D Textures"
By default, homes and renders are saved (save-as when it's working) in the House Plans folder. Late I move them into other folders for organization.
Do you think I should move these folders under my main Documents library folder? It started as images in the "house plans" folder for my home remodeling related projects before I ever heard of Sweet Home 3D and just kept using it after installing SH3D.
[Feb 23, 2024, 10:58:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
Microsoft Windows [Version 10.0.22631.3155]
(c) Microsoft Corporation. All rights reserved.
C:\Windows\System32>"C:\Users\snmav\eTeks\Sweet Home 3D\log.txt"
The system cannot find the path specified.
There is no eTeks folder.
[Feb 23, 2024, 11:02:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
P.S. Wish I could edit my posts.
Maybe it would be better if I uninstall Sweet Home 3D. Reinstall it under it's normal default paths which should create the eTeks\Sweet Home 3D folders and install all the SH3D plugins to start over. My other data folders should be accessible. I feel it's had a short circuit maybe registry settings are borked. What to you think?
[Feb 23, 2024, 11:22:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Installing the program again won’t change anything.
Pleeeaaase, run the program from a cmd window like I proposed.
[Feb 24, 2024, 12:32:34 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sjb007
@snmavronis Daniels gave you an incorrect path to find the log.txt file. This is strange as he wrote that little plugin laughing
C:\Users\<your username>\AppData\Roaming\eTeks\Sweet Home 3D\log.txt
AppData is hidden by default in windows file explorer, so you may need to set explorer to show hidden files if you can't see it.
Or just run the command like Emmanuel asked. Either one should give us more info.
[Feb 24, 2024, 12:59:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
C:\Windows\System32>"D:\Program Files (x86)\Sweet Home 3D\SweetHome3D.exe" 2>"C:\Users\snmav\Desktop\log.txt"
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by javax.media.j3d.JoglPipeline (file:/D:/Program%20Files%20(x86)/Sweet%20Home%203D/lib/java3d-1.6/j3dcore.jar) to method sun.awt.AppContext.getAppContext()
WARNING: Please consider reporting this to the maintainers of javax.media.j3d.JoglPipeline
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
[Feb 24, 2024, 1:05:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
