Previous Thread This topic has been viewed 63922 times and has 90 replies Next Thread
snmavronis
Re: Sweet Home 3D 7.2
I can do a regular file/save of my home from within SH3D, but can't do a file/save-as nor able to save a 3D rendering from the save button. The button does nothing. Obviously it's not folder permissions if I can do a regular save there and copy files there.
[Feb 22, 2024, 10:03:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
But are you able to create a brand new home then save it?
[Feb 22, 2024, 11:01:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
I just created a 12'x12' room with walls and attempted to save it. Nothing happened. When I exit SH3D it asks, do you want to save home? I click save the dialog box goes away. I then go to exit SH3D and it keeps asking me to save it or changes will be lost. The only way I can exit is to click on cancel or do not save and then exit. Yet on my large home model I can open it and it does at least let me "save" changes but not do a save-as so I can give it a new name without overwriting the old one. Strange... I don't know if there is something within my Windows 11 Pro installation blocking SH3D features but this is the only program to have any sort of problem. Here is a list of all installed programs on my PC:
Name & Version
Intel(R) Wireless Bluetooth(R) 22.230.0.2
AMD WVR64 1.0.2
Intel(R) Management Engine Components 1.0.0.0
AMD Radeon USB LED Application 1.0.1
Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 10.0.40219
Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 10.0.40219
Microsoft Visual C++ 2013 x86 Minimum Runtime - 12.0.21005 12.0.21005
Microsoft Visual C++ 2013 x86 Additional Runtime - 12.0.21005 12.0.21005
AMD Settings 2024.0111.1250.2016
Microsoft Visual C++ 2022 X64 Additional Runtime - 14.36.32532 14.36.32532
Apple Software Update 2.7.0.3
iTunes 12.13.0.9
LibreOffice 24.2.0.3 24.2.0.3
ENE_X_AIC_HAL 1.0.6.3
AMD DVR64 1.0.2
WD_BLACK AN1500 1.0.12.0
Microsoft Visual C++ 2013 x64 Additional Runtime - 12.0.21005 12.0.21005
WD_BLACK D50 1.0.9.0
Verbatim_SureFireGaming_Product 1.0.3.11
Microsoft Visual C++ 2013 x64 Minimum Runtime - 12.0.21005 12.0.21005
Dynamic Application Loader Host Interface Service 1.0.0.0
Microsoft Visual C++ 2012 x64 Additional Runtime - 11.0.61030 11.0.61030
Documentation Manager 22.180.0.4
Ableton Push Driver v5.50.0 5.50.0
Intel(R) Icls 1.0.0.0
Bonjour 3.1.0.1
Apple Mobile Device Support 17.0.0.21
Intel(R) ME WMI Provider 1.0.0.0
Intel(R) Chipset Device Software 10.1.19376.8374
ENE_MousePad_HAL 1.0.2.0
4K Video Downloader 4.24.4.5430
Microsoft Visual C++ 2022 X86 Additional Runtime - 14.36.32532 14.36.32532
Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.61030 11.0.61030
Microsoft Visual C++ 2012 x64 Minimum Runtime - 11.0.61030 11.0.61030
ENE Video Capture Box HAL 1.0.5.15
Intel(R) Management Engine Driver 1.0.0.0
Ableton Live 11 Lite 11.0.0.0
Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.61030 11.0.61030
Microsoft Update Health Tools 5.72.0.0
Microsoft Visual C++ 2022 X86 Minimum Runtime - 14.36.32532 14.36.32532
WD P40 Game Drive 1.0.2.18
Branding64 1.00.0009
ENE_External_Device_HAL 1.0.11.1
Microsoft Visual C++ 2022 X64 Minimum Runtime - 14.36.32532 14.36.32532
ENE_EHD_M2_HAL 1.0.12.2
AMD User Experience Program Installer 2340.0.0.111
[Feb 23, 2024, 5:02:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
As a temporary solution you can copy the sh3d file and rename the copy to the new name you want.
If windows complains about that you know it's something with windows and not Sweet Home 3D. Maybe file creation rights in windows.
ETA: oeps, missed that is not save-as for the project but for renderings. Ignore my post.
[Edit 1 times, last edit by Keet at Feb 23, 2024, 7:43:29 PM]
[Feb 23, 2024, 5:40:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Keet, this solution won't fix Steve's problem to save photos. It looks like Sweet Home 3D is just unable to display a file dialog box in Steve's case.
Steve, could you check if there's some error log that could explain your issue?
Please open a cmd window and run Sweet Home 3D redirecting errors to a file with a command like:
"C:\Program Files\Sweet Home 3D\SweetHome3D.exe" 2>Desktop\log.txt
Then choose File > Save as menu item in Sweet Home 3D and quit. If the file log.txt contains something, please post it here.
[Feb 23, 2024, 5:54:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
If we are lucky then there will be some java stacktrace written to stderr. You may apply the following steps to help us identify the problem:
1) Download this plugin and place it under "C:\Users\your_username\eTeks\Sweet Home 3D\plugins".
2) Start SH3D and reproduce the problem, then close SH3D (press cancel if required).
3) Open the file "C:\Users\your_username\eTeks\Sweet Home 3D\log.txt", copy the content and post it here (please use the Code button to format the text).
P.S. for Emmanuel: sorry, we have written at the same time.
[Edit 1 times, last edit by Daniels118 at Feb 23, 2024, 6:02:20 PM]
[Feb 23, 2024, 5:59:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
I just realized the text export I did was not the main software list. It must be dependent sub-programs and other stuff. Here is a list that I just hand typed because you can't copy/paste from the Settings screens:
4K Video Downloader
Abelton Live 11 Lite
AMD Product Verification Tool
AMD Software
Arcade Game Series: Galaga
Arcade Game Series: Ms. Pac-Man
ASIO4All
Audacity
Bonjour
Canon IJ Printer Assistant Tool
Canon IJ Scan Utility
Canon TS6400 Series Driver
Corsair iCUE5 Software
CPUID CPU-Z MSI
Dashboard
DesktopOK
Discord
DOOM
Flight Of Nova Demo
Focusrite Audio drivers
GIMP
Google Calendar
Google Chrome
Guitar Pro 8
Intel Management Engine Components
iTunes
LibreOffice
MalwareBytes Pro
Microsoft Edge
Microsoft Edge WebView2 Runtime
Microsoft Visual C++ 2012 Redistributable (x64)
Microsoft Visual C++ 2012 Redistributable (x86)
Microsoft Visual C++ 2013 Redistributable (x64)
Microsoft Visual C++ 2013 Redistributable (x86)
Microsoft Visual C++ 2015-2022 Redistributable (x64)
Microsoft Visual C++ 2015-2022 Redistributable (x86)
MSI Center SDK
Notepad++ (64-bit x64)
OpenShot Video Editor
Pinball Arcade
Quake
Quake Champions
Quake Live
Realtek Audio Driver
Remote Desktop Connection
Standard Soundbank
Steam
Sweet Home 3D
VLC Media Player
[Feb 23, 2024, 10:32:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for this list but it won’t help me to solve your issue (yet).
Please try to get the error logs as explained in my previous post.
[Feb 23, 2024, 10:50:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
I installed the plugin but I can't find the log.txt file that would have been created today. I searched my entire computer.
Just to note the SH3D program on my PC is installed at:
"D:\Program Files (x86)\Sweet Home 3D"
All my saved data (house plans folder) files, renders, plugins etc. are located at these locations:
"C:\Users\snmav\Pictures\House Plans"
"C:\Users\snmav\Pictures\House Plans\Custom"
"C:\Users\snmav\Pictures\House Plans\Models"
"C:\Users\snmav\Pictures\House Plans\OldSH3D"
"C:\Users\snmav\Pictures\House Plans\Plug-ins"
"C:\Users\snmav\Pictures\House Plans\Renders"
"C:\Users\snmav\Pictures\House Plans\SH3D Models"
"C:\Users\snmav\Pictures\House Plans\SH3D Textures"
By default, homes and renders are saved (save-as when it's working) in the House Plans folder. Late I move them into other folders for organization.
Do you think I should move these folders under my main Documents library folder? It started as images in the "house plans" folder for my home remodeling related projects before I ever heard of Sweet Home 3D and just kept using it after installing SH3D.
[Feb 23, 2024, 10:58:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
Microsoft Windows [Version 10.0.22631.3155]
(c) Microsoft Corporation. All rights reserved.
C:\Windows\System32>"C:\Users\snmav\eTeks\Sweet Home 3D\log.txt"
The system cannot find the path specified.
There is no eTeks folder.
[Feb 23, 2024, 11:02:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
