Previous Thread This topic has been viewed 63961 times and has 90 replies Next Thread
YGYL
Re: Sweet Home 3D 7.2
The translation guide is mostly useful to start a new translation.
As I finally tried to update Chinese translation from words existing in Sweet Home 3D + some very cautious use of web translation tools, it's almost ready (except for posture names) and I mostly need YGYL to check if it's ok. May I write you directly?
Yes, my email is 233410614@qq.com
I'm not sure if you can receive a reply
[Sep 14, 2023, 4:06:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
If it were only that simple crying
You and Emmanuel have wright.
I've tried to find a general formula but I've fail (until now).
A possibly workaround could be to have a specific prefix for fixed part (only one) on every adjustable model prefixed with sweethome3d_fixed_[part-name] like sweethome3d_fixed_exterior-frame
which could be used as references for YXZ.
I could also to add another custom property to roof windows and, to plugin, a deformation listener but this will produce a significant slowing of the entire program.
So, at that moment, I will let it as is.
With/Without this I'm wait the final 7.2 release to enjoy discovering the news love struck
[Sep 15, 2023, 6:23:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hello,
Here's the last beta of Sweet Home 3D 7.2 (I hope).
It provides last translations (thanks YGYL) and improvements in the 3D view handling.
Moved objects should now better follow the mouse cursor along the horizontal axis, and I also added the ability to rotate the selected piece of furniture in the 3D view when you press Ctrl + Shift keys before pressing the mouse button to rotate it (alt / option + shift under macOS). Thanks for your tests.
[Edit 1 times, last edit by Puybaret at Sep 22, 2023, 6:06:13 PM]
[Sep 20, 2023, 5:22:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
No need for that. If a part doesn't have a deformation string it should stay where it is, 'simple' as that. Only the deformation parts should move.
[Sep 20, 2023, 6:18:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Here's the last beta of Sweet Home 3D 7.2 (I hope):
I'm going to try it. The previous beta worked quite nicely as well.
[Sep 20, 2023, 6:20:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The final version of Sweet Home 3D 7.2 is out with a few more corrections in 3D handling.
Thanks to all for your feedback and your tests smile
[Sep 22, 2023, 6:05:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
JonnyD
HI Emanuel - how long before it's on the Mac App Store please?
[Sep 23, 2023, 7:57:39 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Probably 2 or 3 days
[Sep 23, 2023, 10:26:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
JonnyD
Can’t wait! I just posted a good review because I was fed up with some of those I’d read, where people just haven’t bothered to learn how to use SH3D
[Sep 23, 2023, 12:29:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
For anyone who is not whatching the dedicated thread, I inform you that I've just released the version 4.0 of Pan 3D View plugin which is compatible with SweetHome3D 7.2.
If you use Wirings and/or 3D dimension lines plugins, please update these too to the latest release available.
A note about 3D dimension lines: since SH3D now supports vertical dimension lines, the plugin is no longer required for most cases, however it is still useful to draw dimension lines with generic orientation in space.
[Sep 23, 2023, 12:51:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
