Re: Sweet Home 3D 7.2
Today, the Beta 8 updates the help in English and French and translations in almost languages (see updated links in the first post of this thread).
Traditional and Simplified Chinese translations are still missing. If anybody want to help, Chinese speaking users would surely appreciate your contribution.
Very willing to provide translations in Simplified Chinese. How exactly can I help you?
There's a nice Translation Guide that describes how you can create translations.
---------------------------------------- Dodecagon.nl 1000+ 3D models, manuals, and projects
The translation guide is mostly useful to start a new translation. As I finally tried to update Chinese translation from words existing in Sweet Home 3D + some very cautious use of web translation tools, it's almost ready (except for posture names) and I mostly need YGYL to check if it's ok. May I write you directly?
Romania
If it were only that simple
You and Emmanuel have wright. I've tried to find a general formula but I've fail (until now). A possibly workaround could be to have a specific prefix for fixed part (only one) on every adjustable model prefixed with sweethome3d_fixed_[part-name] like sweethome3d_fixed_exterior-frame which could be used as references for YXZ. I could also to add another custom property to roof windows and, to plugin, a deformation listener but this will produce a significant slowing of the entire program. So, at that moment, I will let it as is. With/Without this I'm wait the final 7.2 release to enjoy discovering the news
Hello,
Here's the last beta of Sweet Home 3D 7.2 (I hope).
It provides last translations (thanks YGYL) and improvements in the 3D view handling. Moved objects should now better follow the mouse cursor along the horizontal axis, and I also added the ability to rotate the selected piece of furniture in the 3D view when you press Ctrl + Shift keys before pressing the mouse button to rotate it (alt / option + shift under macOS). Thanks for your tests.
[Edit 1 times,
last edit by Puybaret at Sep 22, 2023, 6:06:13 PM]
No need for that. If a part doesn't have a deformation string it should stay where it is, 'simple' as that. Only the deformation parts should move.
Here's the last beta of Sweet Home 3D 7.2 (I hope):
I'm going to try it. The previous beta worked quite nicely as well.
