Previous Thread This topic has been viewed 377635 times and has 90 replies Next Thread
crackwood01
Canada
Re: Sweet Home 3D 7.2
Pardon my ignorance, but i've downloaded the 7.2 Beta 2 file for windows.
After my installation i have a (no plugin 7.2 version) and another 7.1.1 version with plugins installed.
how can i install plugins in 7.2
p.s. my 7.1.1 is a piad version from the microsoft store
[Aug 14, 2023, 7:19:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GaudiGalopin3324
Russia
Thank you Emmanuel. Translucent models are perfectly obtained in the Yafaray version. There are a lot of possibilities now.
[Aug 16, 2023, 12:23:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I'm not sure if it's related to the new version...
When I make a staircase, I can't modify it anymore.
I tried several formats of staircase, in existing or new/blank instance of SH3D, but the result is the same. I can generate the staircase, and in the right-click pop-up menu Modify Furniture is available, but nothing happens. Same result when double-clicking the generated staircase.
I have sent the file to your email.
[Aug 17, 2023, 11:44:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for your reports.
The bug reported by Hans is fixed in the version 7.2 Beta 5, and can be tested with the updated download links in the first post of this thread.
This update fixes also some bugs in the modification of multiple dimension lines and comes with a version of JOGL updated to v2.5.0-rc-20230813.
crackwood01, I thought that the free version and Windows Store version shared the same private data folders but it doesn't seem to be always the case...
You can find their location by clicking on the links showed in the Libraries in use pane, displayed by clicking on the Libraries... button at bottom of About dialog box. If this button is missing, just install a furniture library.
[Aug 17, 2023, 7:08:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thank you very much for your super fast solution. Will test it tomorrow.
[Aug 17, 2023, 8:11:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mirakels
Nice improvements!
Wouldn't the changes to dimension lines (elevation) also not make it easy to create 3 dimensional poylines (i.e. adding elevation to each of the polyline points). Guess that would also make the 3D-wiring plugin much simpler and beter integrated with the core SH3D.
[Aug 20, 2023, 1:32:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Polylines and dimensions are handled differently in 3D: polylines have a variable width in 2D and dash style, but no thickness in 3D, whereas dimensions are lines of fixed thickness with no dash, much more simple and faster to draw!
[Aug 20, 2023, 10:05:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If I need an 'elevated poly line' I use a very thin and narrow but very wide box laughing
That 'poly line' I can elevate, change it's dimensions and position easily, and align with other 'box poly lines' and of course other furniture. Something you can't do with real poly lines. Of course useless for the wiring plug-in but the added ways for manipulation are very useful.
[Aug 20, 2023, 10:16:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
A problem with opening furniture.
When opened the furniture has a different bounding box.
SH3D adjusts X and Y accordingly to keep the base (fixed) part at the correct position.
Not the same with Z.
When the bounding box is changed in the downward direction, the elevation remains the same and as a result the entire window rises.
It happens especially with the turn window when it is used as a roof window.
I have to adjust the window elevation after every opening modification.
Of course the new elevation must be >=0 which is a correct principle.
[Aug 29, 2023, 8:00:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Today, the Beta 6 brings translation updates in Dutch, Italian, Polish, Portuguese, Russian and Swedish (see updated links in the first post of this thread). It also comes with the final release of JOGL 2.5.0.
Dorin, I'm not sure to understand your issue. X and Y coordinates has always designated the center in plan of a piece of furniture, whereas elevation is the lowest point of a piece. Rotating a piece around a horizontal axis doesn't change its elevation to ensure it remains on the ground or the furniture where it's placed.
[Sep 4, 2023, 2:45:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
