Previous Thread This topic has been viewed 27006 times and has 10 replies Next Thread
Making (parts of) walls invisible
Because I sometimes want to hide a part of a wall, I made a small, but very useful object: the invisible wall opening.
It's a variation on the service hatch, but with adapted material properties that make it completely invisible.
I use it
- to hide a ground floor wall in building with more than one floor
- to make an overhanging second floor
- to make passages in a wall without a door frame
- to make two rooms on the second floor, but just one room on the ground floor
I attach the file. When you import it, you won't see a picture, but that's to be expected with invisible objects :-)
Attachment wall_opening_invisible.zip (1415 bytes) (Download count: 14595)
[Jan 3, 2010, 2:22:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
yafeng
Re: Making (parts of) walls invisible
@Hans: Is this still supposed to work in version 2.3? Seems it doesn't work to me. I can move the object into a wall, but it won't create a transparent area. Did I do something incorrectly?
[Apr 10, 2010, 12:06:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Yafeng:
While importing the file I provided, did you check the box Door or window ??
[Apr 10, 2010, 6:38:58 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
yafeng
@Hans: right, it works after "Door or window" option is selected.
However, this still won't solve my original problem. My original problem is how to put two windows, which are vertically overlapping on the same wall. I tried one trick you mentioned, meaning export and then import a window without checking "Door or window". However, such a window, after putting to wall, does create the see-through part, meaning it's just a window attached to concrete wall.
How could I solve that problem? I also tried multi layer walls. It works. However, after I aligned one wall on top of the other one, the two walls don't look like one piece, the brightness or something is different. Wierd thing is, the two walls look fine in camera view after rendering.
[Apr 10, 2010, 12:04:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Ruwan
Great.it helped ma to create multi-level house
[Jan 6, 2011, 8:41:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
KaFe
confused Re: Making (parts of) walls invisible
Dear Hans,
thanks for your great work. I like it very much. applause
But recently I was in need for an invisible wall opening in shape of a triangle. Can you tell me, if I can get it somewhere? Unfortunately, I'm not able to create objects like this myself. I hope, you can help me. Thank you very much.
Karl
[May 5, 2012, 5:56:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Karl,
To make a triangular wall opening, you could do the following:
1 - insert an invisible wall opening
2 - insert one or two visible triangles to change the shape of the rectangular wall opening.
You can find the invisible wall opening here, and the triangle here.
Make sure that you rotate the triangle during importation, so that it has the desired orientation.
[May 5, 2012, 8:36:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
chrispy1970
Thx Hans
Very usefull object
Greetz Chrispy
[Jun 2, 2012, 2:30:58 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
chenjs
Thanks Hans,
Just what I needed. Was like magic.
Pete
[Aug 29, 2012, 3:19:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Tanja108
HI Hans,
I am new here and have a question regarding this invisible wall object you created.
I imported it and I checked the box "Door and Window" , but still it won't create a transparent area when I am moving the object into a wall.
I am working with SweetHome 3,5. Do you have any idea?
Thank you so much, Tanja
[Sep 5, 2012, 3:15:39 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
