Re: Roof with dormers and many corners and pitches // Dach mit Gauben und vielen Ecken und Neigungen
@Hansmex - I tried but I think I was really in geometry in school :D I get messed up in the 3D world. Anyway, I haven't taken time to test all those new possibilities. I think, I will get a good result.
@Keet As understood, there is no way in SH3D to make a whole into an object. I have to do this in another program
What you explained, will be a great help in some situations. But this time I meant, how can I find objects, which were made invisible. But now I am thinking, they still must be in the list in the bottom left corner. (and indeed they are)
Now I have experimented with the roof parts. It looks quite good. The angle in the "ridge" is now wrong because I inserted the dormers at the ends. But that would be OK. However, I can only change the size if I keep the proportions and then it doesn't fit on my surface anymore. Ideas?
Ideally, the ridge would also be pointed, but I would have the dormers at the ends...
I did the following, resize the rood without the middle part (doesn't bother about proportions)... then add the middle part. I had to manipulate the height and so on and I am not sure, wether this is the best method, but hey, it 's a little bit more similar to what I needed...
Romania
This is what I've done in few hours. Of course it is more to work.
And HERE is the file (my vision)
