Total posts in this thread: 4
Previous Thread This topic has been viewed 2566 times and has 3 replies Next Thread
vasilisa123
The problem with the late display of furniture
The furniture in the lower field of the program is not displayed immediately, but only after I add the next furniture after it. And after moving the furniture completely disappears. This is very strange and needs to be fixed somehow. The problem occurs both when installing the latest version of the program and on older versions. I haven't used the program on my laptop before. Geforce 940 MX graphics card.
If I use the online version of the program, there are no problems, but I would like to work offline.
[Jun 20, 2023, 9:10:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: The problem with the late display of furniture
This kind of bug may leave some traces in the console output.
If you’re under Windows, please run cmd, drag and drop SweetHome3D.exe in the cmd window, add a space and the parameter 2> output.txt, type return key and try to reproduce the bug.
This will create an output.txt file that you can share or send to me .
[Jun 22, 2023, 3:07:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
vasilisa123
I sent the contents of the file to the address you specified [email protected]
[Jun 22, 2023, 8:41:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
vasilisa123
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by javax.media.j3d.JoglPipeline (file:/C:/Program%20Files/Sweet%20Home%203D/lib/java3d-1.6/j3dcore.jar) to method sun.awt.AppContext.getAppContext()
WARNING: Please consider reporting this to the maintainers of javax.media.j3d.JoglPipeline
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
[Jun 25, 2023, 5:59:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
