Belgium
accurate measurements
I'm starting an apartment refurb from bare walls. so i've taken accurate measurements. now I try to correct the ground plan of the apartment. I'm stiffled by putting in the measurements, in the more difficult areas I create a measurement first then fit the wall to the measurement, but when I do create the measurements i'm anything between 2 and 6mm off I cannot create a measurement of 580mm itś either 579 or 584. I'm working on a zoom factor that gives me 2.5m x 1.7m on a 1928x1080pix 23'screen
Re: accurate measurements
Zoom in the plan to get more accurate dimensions or enter its length while drawing a new dimension after pressing Enter key. See help about dimensions for more details. This video might also interest you.
Belgium
Thx the video helped a lot i now have rooms to the correct dimension and with the automatic dimension feture i have correct measurements also for most furniture like doors/ windows the video also answers to a large extend my other questions about joining walls
However Iḿ in dire need of a method to create accurate measurements that cannot be automatically generated like in the video, using the mouse it the pointer jumps 3-7 mm (at maximum zoom while still workable) and I cannot use the enter key to edit the measurement from the keyboard
For walls you can also adjust the X and Y coordinates of the start- and endpoints and the 'Distance between endpoints'. If you use the 'Distance between endpoints' to change the length of a wall be aware that it extends in the direction of the wall (see the arrows on the wall in the 2D window). If needed you can reverse the wall direction from the wall context menu (right click on the selected wall). For objects you can use the width/depth/height properties to adjust it size and of course the X/Y coordinates to change it's position.
Make sure you install the AdvancedEditing plugin. It's a must-have for Sweethome3D. With it you can select any object and rotate/move them. This means you can select a room with walls and furniture, polylines and dimension lines, and move them all in one go. You can even move a complete house by selecting "Select all on all levels" from the Edit menu and then move the whole lot with the move function from the plugin.
The smallest unit is 1mm although you can use more decimals after the first. They don't show in the UI but they work. They also are lost when you manually move again.
---------------------------------------- Dodecagon.nl 1000+ 3D models, manuals, and projects
Belgium
Thanks I have the advanced editing tool installed my question is about a measurement that cannot be derived from the dimension of an object eg the measurement between 2 opposing walls across 2 rooms, where the is no single wall . If I read you correctly to create a particular measurement between two objects on the plan I would need to create an object either furniture or a room of that particular size, the create the dimension measurement from that and copy that into the design at the correct location ?
I'm not sure but I think the AutoDimensioning plugin can do what you want. Read about it here , and download the plugin from sourceforge here .
