Re: HELP // 2D plan hidden and stuck in bottom right
What Hans mentioned is also a possibility: your project isn't centered at the 0,0 coordinates. His solution works too (partially) if you can place your project at the 0,0 position.
My solution works when you are way of the 0,0 position which I often have to do: I work with very large projects that span kilometers. To keep it manageable I develop parts in separate projects at the position they have in the merged project and that can be a long way off from 0,0. My trick to enlarge the 2D field then works like a charm.
Dodecagon.nl 1000+ 3D models, manuals, and projects
[Jun 1, 2023, 8:53:57 AM]
[Link]
