Russia
Re: Window Glas
hi. If it is light on the camera side and dark on the other side of the window, there will be reflections. You only need to assign a shine in the middle or maximum to the glass in the window model. If you need a mirror glass in the window, you can simply add a mirror to the glass closely. There will be a reflection. If it's a house outside, you need to assign a texture with clouds to the sky. There will be a reflection of the sky with clouds. Here are windows without mirrors and a few lamps inside the house, even here there are some reflections https://www.mediafire.com/view/nd51ixl72xbpuw...0%25BB%25D0%25B0.jpg/file and here a mirror is attached to the glass, the sky and models of trees around the house are reflected https://www.mediafire.com/view/d98qc0nvyc9fm4...0%25BE%25D0%25BC.jpg/file
