Total posts in this thread: 15
Posts: 15   Pages: 2   [ Previous Page | 1 2 ]
Previous Thread This topic has been viewed 10486 times and has 14 replies Next Thread
Gildaniel
Russia
Re: Second (sometimes even first) instance of SH is not starting
Nope, there is no eTeks folder neither in users, nor anywhere on ssd.
[Oct 22, 2023, 11:44:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Vinci68
For my part, I had moved the program instances to partition D: when I partitioned my disk:
As a result, I found this folder by following this path :
D:>Documents>My_UserName>AppData>eteks>Sweet Home 3D
Perhaps a clue for you !
[Oct 23, 2023, 5:33:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gildaniel
Russia
Bingo, thank you!
I have the log in /users/myusername/appdata/roaming/eteks
So, here is the log when I have one file opened and try to open second one (and nothing happens)
https://woodmouse.ru/test/log-nosecondinstance.txt
[Oct 23, 2023, 6:27:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Hi Gildaniel, this is a known bug of an old version of Pan3dView plugin. Which version are you using? Try to update to a newer one.
See https://www.sweethome3d.com/support/forum/vie...read,5072_offset,80#57000
[Edit 1 times, last edit by Daniels118 at Oct 23, 2023, 6:54:12 PM]
[Oct 23, 2023, 6:49:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gildaniel
Russia
Daniels118, thank you very much, I updated the plugin and now everything is ok!
[Oct 23, 2023, 9:33:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
