PDF Output Flaw
I thought you all might want to know about the output of PDF files from the program. Because of the limited output choices, the method the program offers is a PDF. So when you wish to share the drawings with someone else, they often may not be able to open up the file on their system, whether Mac or Windows, if sending from Debian 11.
However, there appears to be a work around. Take the normal output from SweetHome and save it somewhere. Then open the file in another PDF viewer. From that viewer, save the file again.
Now you have a file that will be openable from the recipient's email client. (This is likely due to a PDF format problem in SweetHome, and is not something that will be fixed.)
