Re: 3D model for pocket door
From this article found on the web, a pocket door seems to be a sliding door that slides into the wall thickness. If I were you, I would use a service hatch:
or a door frame:
to create an opening in the wall.
Then I would place a partio glass door:
imported from 3D models import page.
Thanks Emmanuel, Your definition is correct. I'll follow your suggestion and I compose the object. It'll be an object composed by two other object is there any function that works like "group" in MS office?
Hello Mauma,
There is no "group" function in SH3D, but there is a workaround.
In a separate sheet, draw the entire pocketdoor. Then export it using 3D view -> export to OBJ format. Now import your model using Furniture -> Import furniture and make sure that you click and activate Door or window in the third screen. That way you can insert the completed pocket door in your wall.
The same procedure also works well to make you own furniture.
[Edit 2 times,
last edit by hansmex at Jan 3, 2010, 1:00:28 PM]
