Total posts in this thread: 4
Previous Thread This topic has been viewed 2279 times and has 3 replies Next Thread
function10
love struck How do I close my walls?
When I draw 4 walls, how can I get the ending of wall 4 to neatly fit with the starting point of wall 1?
Looking at the image below, my problem is the left hand corner. The right hand corner is not boxy. The right hand side corner is an automatic join when I click several times to place multiple walls.
[Nov 19, 2022, 12:23:56 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How do I close my walls?
Double click on the start point (the starting wall will be colored when you approach it), or afterwards, use the Plan > Join walls menu item (see this article).
[Nov 19, 2022, 3:06:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Select the two walls you want to connect, right click, and choose 'Join walls' from the context menu.
[Nov 19, 2022, 3:07:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
function10
Thank you Puybaret & Keet.
I did not see that info here: https://sweethome3d.com/userGuide.jsp#drawingWalls
[Nov 20, 2022, 1:45:29 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
