UPVC Windows
Newby here !! I am looking for UPVC casement windows to add to my design They must be like https://www.modernupvcwindows.co.uk/window.php?t=11 with two large opening panes and a central top opening pane I can't see anything like that in the library - which is surprising - they are a common fitment in UK Thanks
Croatia
Re: UPVC Windows
Many users have specific requirements for certain 3D objects. The best way is to find some free 3D software that is easy to use and learn how to work with it, which should not be a big problem. It is important that it can export the created object in *.3ds or *.obj format. Usually these objects consist only of primitive objects, cube, cylinder, sphere, etc. It must have the ability to assign texture maps or colors to individual parts. That's all. The time spent on learning will pay off very quickly, especially if someone has a desire to deal with it and it is a pleasure for them. I hope I helped. If not, I can make a model of the window you need, and send you the model to your email. Good luck in finding the window model in question.
