Total posts in this thread: 109
Posts: 109   Pages: 11   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 99017 times and has 108 replies Next Thread
cyphorage
Re: Weird 3D Artifacts
Just confirming that this is still an issue with latest Adrenaline driver (22.9.1) released yesterday (2022-09-21)
https://www.amd.com/en/support/kb/release-notes/rn-rad-win-22-9-1
Does anyone know the exact crux of the issue so that we can report it directly to AMD?
I reported this as a bug to AMD directly with their bug reporting tool. Instructions for doing so can be found here: https://www.amd.com/en/support/kb/faq/amdbrt. I have linked to this thread for further reference along with uploading some relevant screenshots. Hopefully that helps them
Just updated to 22.9.2 (released today, 2022-09-27) and the issue persists. I will be reporting this bug to AMD again.
[Sep 27, 2022, 10:24:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
quallemalle
I recently switched my GPU from Nvidia to AMD and also can confirm this bug with 22.10.1 driver :/ Will create a bug report
[Oct 21, 2022, 2:31:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
coldcomfort
Just happened to me too. I had no issues the other day and made no driver or windows update since (did install a new firewall). Only installed a few sweethome3d plugins the last time, but all worked just fine then.
The 3d view window is grey now when opening the program, with no model. Then loading a model gives those artifacts above, in both the 3d view and planview (objects are all black). And everything is a mess. Tried reinstalling and got the same issues.
AMD Radeon Vega 8 integrated graphics
[Edit 6 times, last edit by coldcomfort at Oct 24, 2022, 5:06:15 PM]
[Oct 24, 2022, 4:19:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Could some of you try Sweet Home 3D executable jar with a recent version of Java 17:
- download Java 17 and install it
- download Sweet Home 3D executable jar
- open a cmd window and run the command:
java --add-opens=java.desktop/sun.awt=ALL-UNNAMED --add-opens=java.desktop/com.apple.eio=ALL-UNNAMED --add-opens=java.desktop/com.apple.eawt=ALL-UNNAMED -jar path\to\SweetHome3D-7.0.2.jar
(to get SweetHome3D-7.0.2.jar file path easily, drag-and-drop the file in the cmd window).
I wonder if it would run better, it could also worth to try the 32 bit version of Sweet Home 3D.
[Edit 1 times, last edit by Puybaret at Oct 24, 2022, 6:28:28 PM]
[Oct 24, 2022, 6:24:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
coldcomfort
I fixed it by reinstalling my radeon software, with a factory reset. Downgrading to the 22.5.1 version.
[Edit 1 times, last edit by coldcomfort at Oct 25, 2022, 11:06:00 AM]
[Oct 25, 2022, 11:05:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
quallemalle
Tried out running the jar with Java 17 as you mentioned but it did not fix the issue :/ (AMD Driver 22.10.3)
[Oct 28, 2022, 3:55:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GeoYla
Just ran into this problem as well... so I guess we have to wait for AMD to fix it? Shame.
[Oct 31, 2022, 7:44:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You’re not obliged to wait for AMD good will, just downgrade to version Adrenaline 22.5.1.
[Oct 31, 2022, 10:38:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
nerderepso
Same problem here: 6600XT, Adrenalin "pro" 22.Q3, SweetHome 3D v7.0.2
[Nov 7, 2022, 1:01:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Emendebal
I can confirm this issue: There are strange black lines in the 3d preview, that seem to be centered around some kind of object outside of the house model. When moving the 3dview, the black lines randomly are disappearing and reappearing, (seems to be bound to the displays refresh rate?), creating kind of like a flicker-effect.
I am on a Radeon RX5600XT, the problem appears with Adrenalin 22.10 and also 22.9. Downgrading to 22.5 indeed solved the problem for me! I will try to report to AMD too.
[Nov 9, 2022, 12:15:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
