Does anyone know the exact crux of the issue so that we can report it directly to AMD?
I reported this as a bug to AMD directly with their bug reporting tool. Instructions for doing so can be found here: https://www.amd.com/en/support/kb/faq/amdbrt. I have linked to this thread for further reference along with uploading some relevant screenshots. Hopefully that helps them
Just updated to 22.9.2 (released today, 2022-09-27) and the issue persists. I will be reporting this bug to AMD again.
Re: Weird 3D Artifacts
Just happened to me too. I had no issues the other day and made no driver or windows update since (did install a new firewall). Only installed a few sweethome3d plugins the last time, but all worked just fine then.
The 3d view window is grey now when opening the program, with no model. Then loading a model gives those artifacts above, in both the 3d view and planview (objects are all black). And everything is a mess. Tried reinstalling and got the same issues.
AMD Radeon Vega 8 integrated graphics
[Edit 6 times,
last edit by coldcomfort at Oct 24, 2022, 5:06:15 PM]
Could some of you try Sweet Home 3D executable jar with a recent version of Java 17: - download Java 17 and install it - download Sweet Home 3D executable jar - open a cmd window and run the command:
(to get SweetHome3D-7.0.2.jar file path easily, drag-and-drop the file in the cmd window). I wonder if it would run better, it could also worth to try the 32 bit version of Sweet Home 3D.
[Edit 1 times,
last edit by Puybaret at Oct 24, 2022, 6:28:28 PM]
I fixed it by reinstalling my radeon software, with a factory reset. Downgrading to the 22.5.1 version.
[Edit 1 times,
last edit by coldcomfort at Oct 25, 2022, 11:06:00 AM]
You’re not obliged to wait for AMD good will, just downgrade to version Adrenaline 22.5.1.
