Previous Thread This topic has been viewed 1423 times and has 2 replies Next Thread
hammm3r
Need help - how do I configure yafaray?
3rd time posting, my posts aren't going through.
I've searched for how to configure yafaray, but I can't find where the settings are. In particular, I'd like multiple bounces on the light rays.
[Jul 17, 2022, 6:27:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Need help - how do I configure yafaray?
The messages posted in this forum are moderated to avoid spam. It was indicated after you posted you message but you probably missed the note.
There’s no easy way to configure the special settings of YafaRay renderer yet and you should choose the setting you want from the properties listed in YafarayRenderer.properties and set the Java properties at program launch.
If you want change bounces, you’ll have to set the properties com.eteks.sweethome3d.j3d.YafarayRenderer.highQuality.diffusedBounces and probably com.eteks.sweethome3d.j3d.YafarayRenderer.highQuality.lightingMethod,
for example with Java options
-Dcom.eteks.sweethome3d.j3d.YafarayRenderer.highQuality.diffusedBounces=3 -Dcom.eteks.sweethome3d.j3d.YafarayRenderer.highQuality.lightingMethod=pathtracing
Setting these options depends on the operating system you use. Look at the FAQ about increasing memory to pick up the good option.
[Jul 17, 2022, 10:01:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You're lucky, Enkonyito already added the new YafaRay settings in the new version 1.4 of his AdavancedSettingsPhotoRendering plug-in.
I will be easier to set them with this plug-in than manually editing the properties value.
[Jul 18, 2022, 8:53:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
